Old 01-07-2015, 05:45 PM   #1
Harley03joe
Harley03joe's Avatar
Smile Need Pro's & Con's On The F-100 Steering Box
I'm Looking For Pro's & Con's On The F-100 Steering Box, From
Randy Gross
Son of Mel & Jackie Gross
Please Let Me Know What You Folks Think, To Make Steering Easy
Thank You
Harley03joe
Harley03joe is offline   Reply With Quote
Old 01-07-2015, 05:54 PM   #2
willobs
Default Re: Need Pro's & Con's On The F-100 Steering Box
I have one all pros no con's. Also great support from Randy
willobs is offline   Reply With Quote
Old 01-07-2015, 05:59 PM   #3
CarlG
CarlG's Avatar
Although mine is not from Randy (or Mel), I love it.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-07-2015, 06:16 PM   #4
Harley03joe
Thank You For The Info I Love The Easy Steering I'LL Get
Thanks
Harley03joe
Old 01-07-2015, 06:17 PM   #5
Harley03joe
Smile Re: Need Pro's & Con's On The F-100 Steering Box
Where Did You Get Yours ??
Thanks
Harley03joe
Old 01-07-2015, 06:18 PM   #6
CarlG
CarlG's Avatar
Originally Posted by Harley03joe View Post
Where Did You Get Yours ?? ...
Modelaonly.net
Alaskan A's
Old 01-07-2015, 06:44 PM   #7
Harley03joe
Modelaonly.net
Ok Thanks
Old 01-07-2015, 06:48 PM   #8
Anteek29
Anteek29's Avatar
I am planning to do the same install, so I am happy to read the positives.
My 7 tooth box is worn to the point where the steering wheel has 4" of play.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 01-07-2015, 07:07 PM   #9
Harley03joe
Wow 4" Of Play Thats A Lot
Are You Going To Get It From
Randy Gross
(714) 292-8660
Old 01-07-2015, 08:28 PM   #10
Smog Tech
Smog Tech's Avatar
I have an F-100 steering gear from Mel Gross in my Model A. Love it!! Talk to his son Randy, great guy to work with.
Smog Tech is offline   Reply With Quote
Old 01-07-2015, 08:33 PM   #11
harleynut
harleynut's Avatar
I put one in my 28 two years ago.......I do like it......thought it was really pricey but I bought it anyway. Not hard to install. Good support from those guts
harleynut is offline   Reply With Quote
Old 01-07-2015, 08:37 PM   #12
hardtimes
hardtimes's Avatar
Randy Gross
Thank You
Harley03joe
Hey Joe,
You will not go wrong with this equipment...as I noticed easy steering immediately. NO one who has looked into engine compartment even notices that it ain't original ! And, who cares if one of a hundred does anyway
hardtimes is offline   Reply With Quote
Old 01-07-2015, 08:41 PM   #13
Big hammer
IMHO a overhauled A gearbox is the way to go. Disassembled my first 2 tooth at age of 16
Cleaned,reassembled and ADJUSTED properly work good for me! Was not hard to steer returned to center and no more play. When adjusting you need to follow each step !
Old 01-07-2015, 09:57 PM   #14
southfork
southfork's Avatar
Does any one know if the steering boxes in the 1953-1957 Ford 3/4 tons are the same box and gears as the 53-56 1/2 ton F-100s? The box looks the same externally. If so, I know where to nab one.
southfork is offline   Reply With Quote
Old 01-07-2015, 10:11 PM   #15
SSsssteamer
SSsssteamer's Avatar
I just finished rebuilding the seven tooth for my 1929 Tudor. I was able to get all of the parts needed new, except the worm on the steering wheel shaft. I had to reuse my old worm which wasn't too bad. I also had to use my lathe to turn down the end of the steering wheel shaft to true again. I guess that they all need it. Then I had to ream the new bushing to fit the bottom end of the shaft. All said and done, it needed the rebuild as it also had 4 inches of lost motion in the steering wheel, but next time I would rebuild a two tooth gear box for it. The two tooth has more adjustments to keep the steering gear with in its operating limits. The seven tooth only has two adjustments and that is not enough adjustments. F 100 gear box? It is not necessary to use when the two tooth box has rebuild parts available for it. I rebuilt the two tooth gear box for my 1930 Std Phaeton and it works like a dream.
SSsssteamer is offline   Reply With Quote
Old 01-07-2015, 10:18 PM   #16
Ron Lachniet
Ron Lachniet's Avatar
I adapted a F100 steering box and am very happy with it. I bought another one in case someone else in our club wanted one but when I got it I found that it was off from a larger truck and the dimensions were slightly larger. I think it would work but sold it again because I wasn't sure if it would have enough clearance on the engine side of the box. I asked if anyone had tried it on the Hamb site but never got an answer.
Ron Lachniet is offline   Reply With Quote
Old 01-07-2015, 11:00 PM   #17
Gerald D. Walker
Gerald D. Walker's Avatar
I have the F100 steering box and it's great. Has anyone found any additional improvement installing the shortened Pitman arm too?
Gerald D. Walker is offline   Reply With Quote
Old 01-08-2015, 09:45 AM   #18
V4F
V4F's Avatar
I also have one of mels boxes . like it .........
V4f
V4F is offline   Reply With Quote
Old 01-08-2015, 10:43 AM   #19
TnA
the steering shaft enters the top of the box on the f100, problems for a 8ba exaust. the f1 box steering shaft enters the lower portion of the box . more room for headers/ manifold.
TnA is offline   Reply With Quote
Old 01-08-2015, 10:50 AM   #20
CarlG
CarlG's Avatar
I would be interested in this aspect as well.
Alaskan A's
