Old 01-03-2015, 07:58 AM   #1
bullrunmotor
Default 1935 Ford Front Seats-Dimensions
Can anybody tell me if a 1935 4 Dr. Sedan Front Seat will interchange with a 1935 Coupe Front Seat-both are bench seats-but I can't find any specs regarding sizes. I need a good seat for my Coupe and have found a 4 Dr that is getting the street rod treatment so the interior is avaialble. Thanks in advance.
bullrunmotor is offline   Reply With Quote
Old 01-03-2015, 02:24 PM   #2
uncle buck
uncle buck's Avatar
Default Re: 1935 Ford Front Seats-Dimensions
Yes, physically it will fit and serve its function. If you are worried about correctness , its totally different
uncle buck is offline   Reply With Quote
Old 01-03-2015, 09:43 PM   #3
flathead47
flathead47's Avatar
X2 what Uncle Buck states.
The metal base of the 4dr seat is the same as the coupe metal base.
The lower metal side connection plate attached to the coupe side wood is different , but I believe Bob Drake is or will be reproducing this plate.
Wood kits are available for the back frame & both seat spring assemblies , so you can make a coupe seat assembly.
flathead47 is offline   Reply With Quote
Old 01-03-2015, 11:06 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Are you located in Northern Virginia? If you would rather have a '35 coupe seat, I may be able to help. Send me a pm if you have any interest.
John
Old 01-04-2015, 12:13 AM   #5
rich b
rich b's Avatar
Who is the source of the seat back wood? Thanks
rich b is online now   Reply With Quote
Old 01-04-2015, 11:47 AM   #6
Randy in ca
Randy in ca's Avatar
WoodArt
http://www.fordwoodart.com/
Randy in ca is offline   Reply With Quote
Old 01-04-2015, 01:19 PM   #7
rich b
rich b's Avatar
Originally Posted by Randy in ca View Post
Thanks, I really should have thought of them; but never noticed they had the wood for back cushion.
