Old 09-23-2010, 03:28 PM   #1
Job
Job's Avatar
Question Help with wiring harness
Is it possible and or feasible to use a wiring harness for cowl lights in a car without cowl lights and 2 bulb headlights? If yes, how would it be installed?
Thanks for the help, Job
Job is offline   Reply With Quote
Old 09-23-2010, 03:38 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Help with wiring harness
I would just buy the correct harness.
Yes, you can fix the harness, but you'd have to splice onto the cowl light wire and run a wire to each headlight, so you'd have an extra wire hanging loose. Then you'd have to have the bullet ends soldered on and the correct socket for 3 wires.
Old 09-23-2010, 04:51 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Technically it is very simple;
Splice two wires to the end of the wire that goes to the cowls lights and run one to each headlight small bulb socket.
Old 09-24-2010, 05:11 AM   #4
roccaas
roccaas's Avatar
Or buy a pair of Cat Eye or other driving lights and run them off of the cowl circuit. That's what I did.
Cowl illuminate only for turn signals, and the Cat Eye's are my Daytime Running Lights and occasionally my "get home at night" lights when the halogens have a problem.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
