Old 12-21-2014, 03:20 PM   #1
Zeke...PA
Zeke...PA's Avatar
Default Heaters?
How many cars have heaters, water, exhaust ? Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 12-21-2014, 04:36 PM   #2
42merc
42merc's Avatar
Default Re: Heaters?
My '40 has a hot water heater.
I live in Michigan, can't really enjoy your ride in the spring or the fall without one.
42merc is offline   Reply With Quote
Old 12-21-2014, 05:00 PM   #3
4dFord/SC
4dFord/SC's Avatar
x2.
4dFord/SC is offline   Reply With Quote
Old 12-21-2014, 05:20 PM   #4
Bruce in southern OH
Bruce in southern OH's Avatar
39 Lincoln, exhaust, works great
Bruce in southern OH is offline   Reply With Quote
Old 12-21-2014, 05:52 PM   #5
Joe Immler
'41 coupe with hot water heater. I live in Ohio and X2 what 42merc said
Joe Immler is offline   Reply With Quote
Old 12-21-2014, 05:52 PM   #6
malpais
malpais's Avatar
I've had experience on seven late 30 flatheads. 5 had hot water heaters(two are Ford Script), one has an exhaust heater, one has a Southwind gasoline.
These were all originally in cold weather states: Ohio, Colorado, Nebraska, Wyoming.
I've found it's hard to find fan parts for the Ford Script heaters, and hard to find heat exchangers for the exhaust heaters, if that's a factor for you.
Since they were mostly aftermarket or dealer installed, be hard to find numbers....
Gordon
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes..
malpais is offline   Reply With Quote
Old 12-21-2014, 06:02 PM   #7
1939 pickup truck
The 39 Ford C91 will be getting a Tropic Air added for those fine late fall foliage tours.
1939 pickup truck is offline   Reply With Quote
Old 12-21-2014, 06:28 PM   #8
Tim Brown
Tim Brown's Avatar
Here is what goes into my cars. This is California. We dont need much more than a warm backside....
http://www.heatedseatkits.com/heatedseatkits/index.html
Tim Brown is offline   Reply With Quote
Old 12-21-2014, 06:39 PM   #9
PeterC
PeterC's Avatar
I have a restored 1940 Ford heater (hot water) in my 35 3 window - boy it gets toasty in there fast!
PeterC is offline   Reply With Quote
Old 12-21-2014, 06:45 PM   #10
charles in east texas
charles in east texas's Avatar
I have an exhaust hot air heater. Wife loves it.
charles in east texas is offline   Reply With Quote
Old 12-21-2014, 06:57 PM   #11
RalphG
RalphG's Avatar
Given my location it will come as no surprise that my 39 Deluxe had a heater installed. It is a B.F.Goodrich connected up to the cooling system by hoses. One to the lower right radiator hose and the other to the top of the right head. I removed it years ago for reasons I can't recall but still have it. The stick on glass, later plastic, "frost shields" were standard equipment on cars here in winter. The weak heaters needed a little help in our cold weather.
RalphG is offline   Reply With Quote
Old 12-21-2014, 06:58 PM   #12
deuce_roadster
deuce_roadster's Avatar
3- 40s all have hot water heaters. (wagon, convert, V8 coupe)
Old 12-21-2014, 07:05 PM   #13
Blu Dice
Blu Dice's Avatar
My '52 has a very good stock heater, and since I drive my car every weekend it gets a real work out here.
4 doors are better than no doors!
Blu Dice is offline   Reply With Quote
Old 12-21-2014, 08:50 PM   #14
41ford1
41ford1's Avatar
The pickup has a good working Southwind heater. The stock unit in the '53 Courier provides plenty of heat. I have electric seat heaters in the hot rod for the cooler days.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 12-21-2014, 10:11 PM   #15
47 flatbed
47 flatbed's Avatar
Kept aftermarket heater in my 47. My wife's 41 will have original restored and installed. My 39 3/4 ton will too when that happens all hot water heaters
47 flatbed is offline   Reply With Quote
Old 12-22-2014, 01:54 AM   #16
Fibber Mcgee
Fibber Mcgee's Avatar
My 41 still has original Ford water heater(even has 41 date on back of housing ) but my 49 has an early 50s Western Auto water heater.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 12-22-2014, 07:25 AM   #17
Barry-ct
Barry-ct's Avatar
My 50 F-1 has the factory fresh aire hot water heater installed.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 12-22-2014, 09:23 AM   #18
Ol' Ron
Ol' Ron's Avatar
My truck will have a Vintage Air water heater/ defroster.
Old 12-22-2014, 09:34 AM   #19
rick r
rick r's Avatar
Have a hot water heater/defroster in my 51 Meteor and a hot water heater in my 32 roadster hot rod. Both are old swap meet 6Volt units. Run a resister, both cars converted to 12v
rick r is offline   Reply With Quote
Old 12-22-2014, 10:22 AM   #20
Dick Webber
39 Deluxe has a Ford hot water heater. Went to a lot of trouble and expense to buy and restore it but it works great.
49 F-1 has what I thought was a factory hot water heater but some say it is a Firestone item.
49 Mercury has factory fresh air heater.
I drive these cars year around if the streets free from salt and I really appreciate the heaters
Model A has a manifold heater which is much better than none, and works best on a hot day.
Merry Christmas to all!
Dick Webber is offline   Reply With Quote
