Old 12-06-2014, 03:58 PM   #1
Init1
Init1's Avatar
Default Banjo rear end excessive axle play.
I have a 40 Ford banjo rear end with excessive in and out axle play on the passenger side. The axle
moves about 1/8 of an inch and makes a thunk when going around a corner.
The other side is tight.
The axle nut is torqued to factory spec.
Any ideas what might be causing this ?
Init1 is offline   Reply With Quote
