Old 08-18-2014, 07:08 AM   #1
ajohn
ajohn's Avatar
Default 21 stud flathead
Recently I bought an exceptionally clean 40 sedan in California. The engine is a 21 stud. This is not correct is it? Were any of the 40 V8 engines 21 stud?Thanks, James
ajohn is offline   Reply With Quote
Old 08-18-2014, 07:19 AM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: 21 stud flathead
NO, the last 21 stud was in the early 38 Fords. If you engine is a 21 stud with the water pumps on the front of the block it's probably a 37-38 engine. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 08-18-2014, 07:56 AM   #3
36tbird
If you decide you need a 59A for your '40, I have one down the road in S.A. already built.
36tbird is offline   Reply With Quote
Old 08-18-2014, 02:20 PM   #4
Kahuna
Kahuna's Avatar
Is that year 40, or model 40?
Kahuna is offline   Reply With Quote
Old 08-18-2014, 05:36 PM   #5
deuce_roadster
deuce_roadster's Avatar
Your avatar shows a model 40, which would have a 21 stud engine with the water pumps in the heads.
If your new car is a 1940, then the above info about 21 stud engines ending mid 38 is correct.
