Old 08-07-2014, 03:00 PM   #1
Houbill
Default flathead V8 on engine lift
I want to get my engine (51) to a machine shop. Can I set it on the oil pan? The heads and exhaust/intake manifolds are off
Houbill is offline   Reply With Quote
Old 08-07-2014, 03:05 PM   #2
Russ/40
Russ/40's Avatar
Default Re: flathead V8 on engine lift
Yes, the pan is vey stout. Not to worry. Just sent it down gently.
Russ/40 is offline   Reply With Quote
Old 08-07-2014, 03:10 PM   #3
Houbill
Looking through posts there is talk/pictures of a cradle. Where can I find info on them?
Old 08-07-2014, 03:10 PM   #4
Mark Slight
Mark Slight's Avatar
Houbill,
Yes you can, however I would suggest you build a wooden frame around the engine so it sets on the side of the pan & front and rear not the bottom. If you set it on the bottom of the pan depending how far you are traveling and if it moves or not you could damage the bottom of the pan and the oil pickup.
I'm sure others will have suggestions also.
Mark
Mark Slight is offline   Reply With Quote
Old 08-07-2014, 03:14 PM   #5
V8 Bob
V8 Bob's Avatar
The pan can be easily dented or damaged by setting the engine directly on the pan. Using an old tire or two to cushion the pan and engine is much better, and has never caused any damage on any of my engines during trans port, or while waiting to be hung on a stand or placed on a cradle.
V8 Bob is offline   Reply With Quote
Old 08-07-2014, 04:09 PM   #6
hope
hope's Avatar
Built myself a cradle for the flathead out of 4"x4" for transportation, not verry hard to do.
hope is offline   Reply With Quote
Old 08-07-2014, 04:35 PM   #7
El Rat
I generally use an old truck tire, something pretty robust.
El Rat is offline   Reply With Quote
Old 08-07-2014, 05:52 PM   #8
rheltzel
rheltzel's Avatar
I just bought a stand/cradle from Kurt Stumpf ([email protected]). Great price ($69.40 including shipping), super customer service.
It bolts to the exhaust manifold outlets on the block.
rheltzel is offline   Reply With Quote
Old 08-08-2014, 06:46 AM   #9
Capn John
Capn John's Avatar
Thumbs up Re: flathead V8 on engine lift
Originally Posted by rheltzel View Post
i just bought a stand/cradle from kurt stumpf ([email protected]). Great price ($69.40 including shipping), super customer service.
+1 and he has a variety of items, He has cradles.
http://stumpysfabworks.weebly.com/st..._Products.html
Capn John is offline   Reply With Quote
Old 08-08-2014, 06:55 AM   #10
Capn John
Capn John's Avatar
Old 08-08-2014, 08:14 AM   #11
GreenMonster48
GreenMonster48's Avatar
My 8BA stayed on an engine stand for months on the bell housing bolts. Sat my old motor down on an old tire with oil pan and all, no damage, no problems. The older style flathead with the cast in bellhousing is better suited for the specialized engine stand mount.
GreenMonster48 is offline   Reply With Quote
Old 08-08-2014, 08:23 AM   #12
AnthonyG
AnthonyG's Avatar
My Flatty shipped from Iowa to Jersey with pan sitting on the pallet. Made it with no issues. I did think it was a bit scary when I saw it but it was the first and only flatty I've bought so thought it was normal.
Nomad
AnthonyG is offline   Reply With Quote
Old 08-08-2014, 02:18 PM   #13
Mike51Merc
Mike51Merc's Avatar
Just get one of those large milk crates.
Mike51Merc is offline   Reply With Quote
Old 08-08-2014, 02:25 PM   #14
JSeery
JSeery's Avatar
Think they were referring to the floor stand not the engine stand (but do agree with your comment).
Old 08-08-2014, 04:35 PM   #15
Binx
I use a 8BA car motor mount bracket bolted to a 3' 2X4 with the pan resting on a tire.
Lonnie
Binx is offline   Reply With Quote
