Old 06-04-2014, 07:55 PM   #1
mll1446
Default 46 ford clutch issue
Can someone provide information on how to adjust clutch pedal and how pedal should be in a 1946 ford 3 spd on column
mll1446 is offline   Reply With Quote
Old 06-04-2014, 08:35 PM   #2
ford3
Default Re: 46 ford clutch issue
pedal should have 1 to 1 1/2 inches of free play at the clutch pedal, push the pedal down with your fingers to get a more exact measurement, there is a rod going from the clutch pedal arm to the throw out bearing arm, that is where you adjust the clutch
ford3 is offline   Reply With Quote
Old 06-04-2014, 08:54 PM   #3
mll1446
Free play is that from the top
Or when I release from floor?
Old 06-04-2014, 09:07 PM   #4
ford3
from the top when you depress the clutch pedal, there will be no pressure on the pedal till the throw out bearing hits the pressure plate, man I hope your serious with these questions and not just jacking me around
Old 06-04-2014, 09:14 PM   #5
mll1446
I'm serious just bought the car and when I shift a lot of grinding . I have had model a in past this is first early. V8 thanks for teplied
Old 06-04-2014, 09:16 PM   #6
mll1446
One last thing the Clevis on adjusting rod appears to be all the way out at end of threads
Old 06-04-2014, 09:25 PM   #7
ford3
how much free play do you have at the pedal, if you don't have enough free play the clutch will not release completely from the fly wheel and it will keep turning the trans main shaft and cause gear grinding
Old 06-04-2014, 09:29 PM   #8
mll1446
It appears an inch or 1-1/4"
Old 06-04-2014, 09:30 PM   #9
mll1446
When pushing with fingers
Old 06-04-2014, 10:02 PM   #10
Bassman/NZ
Bassman/NZ's Avatar
As your freeplay seems to be good, I would venture to say the grinding is caused by excessive wear in the clutch plate and/or pressure plate.
Bassman/NZ is offline   Reply With Quote
Old 06-04-2014, 10:02 PM   #11
ford3
then the free play is good
