Old 06-03-2014, 11:13 PM   #1
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Default front spring question
My '36 pickup sits about an inch and a half lower on the passenger side than the driver's. Also, at full droop, the wheel is definitely lower on that side-the shackle is nearly horizontal. It's as if the spring on that side has lost some of its...spring. Is that possible? I measured it and it seems pretty much centered. It has been that way for quite awhile. Thoughts?
Thanks,
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 06-04-2014, 03:44 PM   #2
woodiewagon46
Default Re: front spring question
Adam, I would check the nuts that tighten the "U" bolts that hold the spring into the front cross member, and the "U" bolts. I had a friend that had a similar situation and found that one of the "U" bolts snapped. The other thing I would check is your shackles, one could be frozen. It is possible, but very unusual that one side of the spring could loose it's spring rate.
woodiewagon46 is offline   Reply With Quote
Old 06-04-2014, 08:56 PM   #3
Adam/Mill Valley CA
OK thanks, I'll definitely look at those things. I was thinking myself it would be unusual.
Adam
