Old 05-28-2014, 12:18 PM   #1
Eighty
Eighty's Avatar
Default Round speedometer oiling
Have wondered if small hole in speedometer housing is for oil. Thanks in advance of any information!
Eighty is offline   Reply With Quote
Old 05-28-2014, 12:57 PM   #2
160B
160B's Avatar
Default Re: Round speedometer oiling
The small hole on the back of the case is not a lubrication point.
For the round Stewart Warner speedometer.
Remove the speedometer from the case and on one side there are two brass cups, gently remove each cup and remove the felt wick in each hole. Clean them in a solvent, dry thoroughly, oil them, replace them and reinstall the brass cups. Use a light machine oil.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
Last edited by 160B; 05-28-2014 at 01:29 PM. Reason: clarified application for round SW speedometer
160B is offline   Reply With Quote
