Old 04-05-2014, 04:59 PM   #1
Johnnydidd
Johnnydidd's Avatar
Default 6 lbs pressure
I have dual carbs on my 53 Ford, it has a electric fuel pump. The rear carb is the primary, it has been leaking gas causing the engine to run very rough, I rebuild the carb with a new kit and it ran great for a couple miles then the carb overflowed and ran poor again. I blocked off the rear carb and used the front carb which doesnt seem to leak. Runs great drove it for 10 miles still seem to run rich, black carbon on the ends of the exhaust. The electric pump puts out 6 lbs of pressure.I think its lbs? The jets in the carb are 50s, are the jets to large, pressure to high. I live in Kansas Ciy. Thanks John
Johnnydidd is offline   Reply With Quote
Old 04-05-2014, 05:03 PM   #2
ford3
Default Re: 6 lbs pressure
to much pressure #3 or maybe #4 is plenty, one carb only needs #2 1/2
ford3 is offline   Reply With Quote
Old 04-05-2014, 05:42 PM   #3
waterboychuck
waterboychuck's Avatar
You may want to change out the jets in the carbs to see if that fixes the problem.
waterboychuck is offline   Reply With Quote
Old 04-05-2014, 05:49 PM   #4
flatjack9
flatjack9's Avatar
The jets are fine. Too much pressure.
Old 04-06-2014, 03:01 PM   #5
funrunr
funrunr's Avatar
I'm running dual 97s with 2 1/2 lbs, I have an electric pump for easy starts. 3lbs was too much for mine. If you're running 94's 3lbs might be ok for you. Buy a fuel regulator and try running that before sinking more into the carbs. What carbs are you running and what type of work has been done to the engine?
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 04-06-2014, 03:11 PM   #6
tiquer
I agree with too much pressure 2 1/2 is good
tiquer is offline   Reply With Quote
Old 04-06-2014, 04:28 PM   #7
BobbyG
BobbyG's Avatar
Fit an inline regulator - just before carbs a set it at about 4lbs, that will be more than enough pressure.
BobbyG is offline   Reply With Quote
Old 04-06-2014, 05:13 PM   #8
ford38v8
ford38v8's Avatar
I have an electric pump and regulator by the tank. The regulator is set for 1 1/2lbs. Stock 59L block and 91-94 carb. The pump is used to overcome VL from the mechanical pump, and does just fine in that capaciy.
Alan
Old 04-06-2014, 07:29 PM   #9
Johnnydidd
Johnnydidd's Avatar
Udate: Installed fuel regulator
, set it on 3lbs works great engine idles down, you can barely here her run, very smooth, thanks to all for your excellant advice. John
