Old 03-07-2014, 09:47 AM   #1
36tbird
Default Ain't a Flathead, but gear heads may like it
Not a flathead, but hands on mechanic guys may get a kick out of this.
http://pixelbark.com/13045/how-the-d...bustion-engine
Reminds me of the post a while back about the engine without a cam, valves driven by computer controlled actuators. Anyone know if more has come from that?
36tbird is offline   Reply With Quote
Old 03-07-2014, 10:37 AM   #2
Old Henry
Old Henry's Avatar
Default Re: Ain't a Flathead, but gear heads may like it
This reminds me of the old rotary piston aircraft engines where the whole block and pistons spun around the crankshaft. Never understood how those worked but are fascinating to me as is this duke engine. It just doesn't' seem like it would produce the low end torque that a conventional engine does.
Old 03-07-2014, 10:48 AM   #3
VeryTangled
VeryTangled's Avatar
Amazing, it doesn't have a spark plug for each cylinder!
Anyone know what the application is? Automobiles or marine or what?
-VT/JeffH
More on Wiki: http://en.wikipedia.org/wiki/Axial_engine
VeryTangled is offline   Reply With Quote
Old 03-07-2014, 11:18 AM   #4
Ross F-1
Ross F-1's Avatar
Vacuuming money out of investor's wallets, I would guess...
I don't see any hope of the seals at the top of those cylinders holding out for a hundred thousand miles. I am impressed that they actually have a working prototype, that's more than many of the hundreds of alternative engines can claim.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 03-07-2014, 12:22 PM   #5
ford38v8
ford38v8's Avatar
That's fascinating! The unique problems to overcome must keep them awake nights! This being the 3rd generation, they may be ready for a production decision by about the 10th generation!
Alan
Old 03-07-2014, 12:54 PM   #6
Binx
This is really nothing more than adapting the design of a Vickers rotary variable-volume hydraulic pump.
Lonnie
Binx is offline   Reply With Quote
Old 03-07-2014, 12:56 PM   #7
Ross F-1
Ross F-1's Avatar
Lonnie
Not a whole lot different than a swashplate A/C compressor either.
Old 03-07-2014, 01:57 PM   #8
Jack E/NJ
Jack E/NJ's Avatar
Which do you like better? Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 03-07-2014, 02:27 PM   #9
29AVEE8
29AVEE8's Avatar
Would love to see the valvetrain.
Ignorance of the laws of physics does not mean they do not apply to you.
29AVEE8 is offline   Reply With Quote
Old 03-07-2014, 02:41 PM   #10
Ross F-1
Ross F-1's Avatar
There is none, it is piston-ported like a 2-stroke.
Old 03-07-2014, 02:43 PM   #11
36tbird
"Would love to see the valvetrain."
The gist I got out of it was no valvetrain. Looks like the pistons draw in fuel as they pass a cylinder with an intake port and expel the spent gases when they pass a cylinder with the exhaust port.
Old 03-07-2014, 02:59 PM   #12
Shadetree
Shadetree's Avatar
Looks like the mechanical advantage of the power stroke of the pistons would be lessened on this engine versus a crankshaft engine, generating less torque. Too, it looks like it would require more torque on the compression stroke than a conventional engine.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 03-07-2014, 03:00 PM   #13
sidevalve8ba
sidevalve8ba's Avatar
Correct me if I'm wrong but isn't that basically the same setup as the swash-plate compressors used on modern day auto air conditioning? Sure looks like it to me.
sidevalve8ba is offline   Reply With Quote
Old 03-07-2014, 03:22 PM   #14
Jack E/NJ
Jack E/NJ's Avatar
Yeah, I think so except the Duke plate is the stator while the block with the pistons is the rotor. Like Lou suggests, porting seems similar to the Wankel rotary.
Jack E/NJ
Old 03-07-2014, 05:22 PM   #15
jimTN
Sort of also using the sleeve valve engine concept in a different manner combined with modern rotary design
jimTN is offline   Reply With Quote
Old 03-07-2014, 05:36 PM   #16
Rowdy
Another variation of the radial engine as stated above. Wonder whatever happened to the cam engine being experiemented with in the late 80's. It was somewhat aproved by the FAA and then faded into obscurity. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 03-07-2014, 08:07 PM   #17
Binx
Personally, I'm a big fan of the stationary crank WWI radials with the entire engine spinning with the prop. Full throttle all the time. Kill switch to slow it down. That must have been a handful!!
Lonnie
Old 03-07-2014, 08:55 PM   #18
Lawrie
Lawrie's Avatar
That looks like something flathead Ted would be involved with.
There is a diesel engine in the Motat museum that looks similar.
Lawrie
Lawrie is offline   Reply With Quote
Old 03-07-2014, 10:05 PM   #19
Jack E/NJ
Jack E/NJ's Avatar
The gnome & a few other rotaries at Glenn Curtiss museum, hport, ny
Old 03-08-2014, 07:54 PM   #20
rotorwrench
rotorwrench's Avatar
That rotary wobble plate is going to have a lot of stress on it for the long haul since the power stroke won't be too equal with the opposite strokes. As was mentioned before, It's hard to figure how well the cylinder barrel will seal against the valve plate and not score the hell out of it. It's like an old Frigidaire compressor on steroids. If they used any more than 5-cylinders, it would be as big as a 55 gallon drum.
