#1 |
#2 |
B Model.
#3 |
How can you tell? And what's that extra hole in the head?
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole.
#4 |
#5 |
When mounted on a plane the back of the engine becomes the front.That becomes the highest point of the engine,and all the hot water/stem/vapors go there.Look at a picture of an air camper,you will see a hose arcing up from that hole going back to the radiator behind the engine.
#6 |
#7 |
I have a dual-plug cylinder head for a Funk conversion where the 'A' engine is inverted (for more prop clearance). Anyone want to venture a guess on how the oiling on THAT inverted piece works?? How do you suppose the rod dippers work??
#8 |
Brent, nAQ few days ago I posted the same thing in answer to a inquiry about Radial engines. Inverted Aviation engines are not new. The British DeHaviland "Moth" series (Gypsy moth, Tiger Moth etc) used a 3 cyl inverted power plant. In the PT (primary trainer) 19, they used a inverted 6 cyl inline called the "Ranger". The Germans had a Fiesler "Storch" had a inverted V8 and the ME 109 had a V12 that was inverted. I wish when I was in Aviation classes, in vocational school, I had paid more attention to the radials (Wright Wind, Scarab) we had donated by Navy and just how they prevent Hydro lock on the bottom cylinders. I try to recall and can't.
Terry |
#9 |
#10 |
Oshkosh's collection has this Funk that used an inverted Model B
2012 MARC Oshkosh National Meet 048.jpg 2012 MARC Oshkosh National Meet 050.jpg 2012 MARC Oshkosh National Meet 049.jpg 2012 MARC Oshkosh National Meet 051.jpg |
#11 | |
One way of oiling an inverted A engine crank would be to run distribution lines through the pan, with nozzles aimed at the ascending scoop on the rod, and run a dry sump system. If the bearings are tight, it is amazing at how much oil a plain bearing doesn't need to stay happy, especially at low RPM's. (Prop tip speed considerations). CZ |
#12 |
While the sub title says B, the title and description says A.
#13 |
I guess if you want to sell something on Ebay you call it a Model A part. From then on it's
caveat emptor.
