Old 08-23-2013, 03:10 AM   #1
kwith
Thumbs up 1940 Ford Coupe wheels and rims
Hi, im currently building a 1940 Ford Coupe street rod. Due to Regulation here i Norway it almost impossible to make mods to the frame to be able to fit wider tyres at the rear. So before i make a mistake and order some rims that are either to small or big im wondering if anybody has experience with what i can put on that looks cool, and also is drivable?
If you have pictures that will be appreciated.
Im using a mustag 2 front end 57 inch wide and also a 9 inch rear end 57 inch wide Wheel to wheel.
Kaare
kwith is offline   Reply With Quote
Old 08-23-2013, 04:20 AM   #2
Mart
Mart's Avatar
Default Re: 1940 Ford Coupe wheels and rims
I ran L78:15's on ford pickup rims, they fitted in ok. I don't think I could have used anything much bigger.
I don't know how using the 9" would effect it though.
Old 08-23-2013, 08:40 AM   #3
Dave Mc
Dave Mc's Avatar
is the Lug pattern front & rear the same? I have a pair of Chrysler wire wheels which have a positive offset, they were on a 9 inch in a 34 Coupe which allow wide tires and not protrude past the fender,I will add pics today
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford
Dave Mc is offline   Reply With Quote
Old 08-23-2013, 10:58 AM   #4
kwith
Thanks Dave, yes its the same front and rear end. Ford pattern.
Old 08-23-2013, 12:10 PM   #5
Dave Mc
Dave Mc's Avatar
Here are the 5 on 4 1/2 15 inch wheels I mentioned, notice the Rears have the positive offset,so more of the wheel sets inside the Fender, allowing to have wider tires .the 34 they were on had an uncut 9 inch and the offset was necessary to keep the tires tucked under the fenders
Old 08-23-2013, 12:28 PM   #6
Lanny
Lanny's Avatar
hey Dave, below is a small write-up describing offset. Hope this clarifies it.
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 08-23-2013, 02:06 PM   #7
Dave Mc
Dave Mc's Avatar
Thanks LANNY I corrected it ( see above )
