Old 07-10-2013, 09:33 AM   #1
machine girl
Default condensors
have a new rex modern upper plate, 2 condensors gone bad? they look kinda cheep, thinking of trying a Mallory cond. any help or info?
machine girl is offline   Reply With Quote
Old 07-10-2013, 10:29 AM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: condensors
The Mallorys are just as bad . We use a vertex magneto unit that is the best out there.
They run $25 each shipping included.
Glad to help...
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-10-2013, 11:18 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
I use Mallory dual point distributors in our speedster and my daughters coupe. These distributors were purchased in the ninties and have been maintainance free, I don't know about the newer ones. I personally prefer the original manual advance distributor in my mostly original cars. I would recommend going back to the original upper plate and points and use the short proof A&L condenser that most suppliers sell. I've never had anything but trouble with the so called modern setup.
Old 07-10-2013, 11:32 AM   #4
Kevin in NJ
The later condensers you buy at the stores are done under bulk contracts and are generally not good quality. I know the guys on the Mustang boards have complained about them. I have also heard some of the Harley guys have had problems with the new ones.
The style that A&L makes are likely made with very good quality condensers, they spent the extra $.10 to make the product right. Your best bet is to use them.
The easiest setup to maintain is the original system. With a good set of points (they can even be old used ones) you should be able to get 40+ years of service with proper lubrication.
Kevin in NJ is offline   Reply With Quote
Old 07-10-2013, 12:01 PM   #5
KMeredith87
KMeredith87's Avatar
I went back to the original setup on my pickup after getting some advice on here and couldn't be happier. The original points and super simple to adjust and the condenser seems to be better built and hold up to the heat better. Only thing I haven't done yet is to install the heat shield on the head just for precaution. Good luck but I'd ditch the nu rex unit if I were you.
KMeredith87 is offline   Reply With Quote
Old 07-10-2013, 12:10 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
With the crap condensers for the modern plate many have gone back to the original setup with condensers from A&L.
Old 07-10-2013, 12:15 PM   #7
msmaron
msmaron's Avatar
NEVER had an A&L fail
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 07-10-2013, 12:17 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I had a bad original condenser that I got at a swap meet. Just for kicks I thought I'd cut it open and install a new capacitor. I just did it to see if it would work and intended to use it just long enough to test it. 5 years later, and it's still in my car. See my reply in #17 of this post link:
http://www.fordbarn.com/forum/showth...ndenser+repair
Old 07-10-2013, 01:52 PM   #9
larrys40
I would absolutely get rid of the New Rex setup and go back to the reliable original plate, points,condenser. Use a "burn out proof" A& L unit also sold through brattons and snyders and you should be fine. If you're running some of the performance stuff Bubba may have an alternative for you.... I can most definately say you'll have the least amount of trouble from a stock setup.
Larry S.
larrys40 is offline   Reply With Quote
Old 07-10-2013, 02:30 PM   #10
Duffy1
Had problems similar problems with new rex mosern point dist. Installed dist no fire to point diassembled new dist to find wire coming into dist. grounded out on housing . After I got the car running the condenser lasted about 30 min ,replaced cheapy condenser and points . Let the vendor know I was none to happy with this modern point dist from new rex . Suggested to the vendor that they do a continuety check on these dist. before shipping to customer . Also suggested they put quality points and condensers in these dist.
Duffy1 is offline   Reply With Quote
Old 07-10-2013, 03:07 PM   #11
Patrick L.
Patrick L.'s Avatar
The newer conversions are supposed to fixed, so, just install a good set of points/condensers from NAPA.
Old 07-11-2013, 08:49 AM   #12
klawockvet
klawockvet's Avatar
Do you happen to have NAPA part numbers for the nuRex points and condensers?
klawockvet is offline   Reply With Quote
Old 07-11-2013, 08:56 AM   #13
Bill Steiner
We use a lot of Genuine Ford points and cond. on older Fords at my shop and don't have much of a problem with them. Bill
Bill Steiner is offline   Reply With Quote
Old 07-11-2013, 12:18 PM   #14
Patrick L.
Patrick L.'s Avatar
Nope, I'll try to remember to look. The points/condenser are for a 50s-early 70s Ford. They are the same, however, they are different for 6 cyl vs 8 cyl and I can't remember off hand which these conversions use. The Nurex website may tell or a phone call. Cheap points/condensers for anything has been a problem over the years and good ones are getting pretty expensive.
Old 07-11-2013, 02:15 PM   #15
ctlikon0712
ctlikon0712's Avatar
Try these for the NAPA #'s..... old and new style
Motorcraft DC-1 Condenser
Motorcraft DP104 Point Set
Points CS30 Echlin (original style)
Points CS751 Echlin (new Ford style)
Condenser FA5 Echlin
Rotor FA3 Echlin
Condenser-Mallory Dist MA3 Echlin
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 07-12-2013, 11:19 PM   #16
josh1331
Hey bill. Where can I buy Original pts and condenser for my A. Thought Motocraft discontinued? Thks josh
josh1331 is offline   Reply With Quote
Old 07-12-2013, 11:20 PM   #17
josh1331
Bill see my request posted please as a reply josh
Old 07-13-2013, 10:03 AM   #18
Bill Steiner
Hi Josh. I did not know Motor craft no longer had them them. I got some a while back. I think I got them from O riley but it may have been some other place. I still have a few sets in stock at my shop. I will have to ck around and see if you can still get them. Bill
Old 07-13-2013, 10:08 AM   #19
Bill Steiner
Hi Josh, I was talking about new style points and cond. Not original Model A. I'm talking about the type used on the 60 and 70's Ford, Merc. Bill
Old 07-13-2013, 10:44 AM   #20
Aok
Aok's Avatar
Most coils put out about the same voltage and I think (limited electronic knowledge) that a condenser stores energy so wouldn't most any condenser for point ignitions work well with the new style points.
Aok is offline   Reply With Quote
