Old 05-28-2013, 01:16 PM   #1
30coupeguy
Default radiator fluids
I am just getting ready to reinstall the radiator on my 30 coupe. What is the reccomended ratio of water to anti-freeze/coolant and is there a type that is best to use,or is there anything to avoid?
Thanks
Burt
30coupeguy is offline   Reply With Quote
Old 05-28-2013, 01:25 PM   #2
Bill Steiner
Default Re: radiator fluids
I like Preston glycol , I use 50-50 mix with distal water. Others may say they have foaming problems, but I have never had any problem. Bill
Bill Steiner is offline   Reply With Quote
Old 05-28-2013, 01:32 PM   #3
bill44
bill44's Avatar
I put one gallon (green) in and then fill up the radiator with water. I have a pressurized system. I understand that the stock systems may foam. To avoid that use anti-freeze that is animal friendley. Its made by Prestone.
bill44 is offline   Reply With Quote
Old 05-28-2013, 01:58 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Ditto.
Old 05-28-2013, 02:26 PM   #5
Mitch//pa
50/50
