Old 03-20-2013, 08:38 PM   #1
jkcrosson
jkcrosson's Avatar
Default Turn Signals
I am in the process of adding turn signals to my car. I plan to use the tail light for the rear but undecided about the front. I don't have cowl lights and am not crazy about the look of the logo lights mounted on the bumper. Anyone have any period or or early mounted lights on the front for turn signals. Pictures would be a big help. I'm looking for something that will not look odd on my unrestored car. Thanks
Jamie Crosson
1929 Tudor
Looking for an Original 888 Key
jkcrosson is offline   Reply With Quote
Old 03-20-2013, 09:57 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Turn Signals
I keep looking for period turn signals also. I liked the rear bar with arrows that was posted the other day, and wish it was reproduced. Seems like some small lights the same shape as your headlamps and mounted to the headlamp mounting bolt would look good.
Old 03-20-2013, 10:14 PM   #3
jkcrosson
jkcrosson's Avatar
Thanks Tom. I'm looking at a set of teardrop spotlights with amber lens. I like that look or fog lights from a 34 era ford. Do you think these would be effective mounted on the bumper bracket. Are you suggesting mount the lights beside the headlights? Can you post a link to the bar with arrows you mentioned?
Jamie Crosson
1929 Tudor
Old 03-20-2013, 10:23 PM   #4
31 Victoria
Not exactly what you are asking about, but more 'authentic looking' than most:
http://www.turnswitch.com/Turnsignal.htm
Anybody bought this??
31 Victoria is offline   Reply With Quote
Old 03-20-2013, 10:46 PM   #5
Tom Wesenberg
The first picture in reply # 35 has what I like. They would work as mounted on the headlight bar, and also mounted to the spare tire for the rear.
Old 03-20-2013, 11:15 PM   #6
jkcrosson
jkcrosson's Avatar
Tom,
I cannot find the post you are referring to.
Jamie Crosson
1929 Tudor
Old 03-21-2013, 02:46 AM   #7
Allanw
Allanw's Avatar
Here is ours - maybe not entirely period, but not entirely modern:
It's a set of these:
http://macsautoparts.com/early-v8-fo...0R3CHL1072518/ though mine are only one wire ones, with orange painted bulbs in, and the lenses rotated around to be straight, mounted on a set of these:
http://www.ebay.com/itm/NEW-REPLACEM...item1c312d03b2
but I've taken the clamps off the bottom, and used a longer bolt where the screws go into the top of the chassis to hold the panels in place in front of the radiator (if that makes sense!).
By angling the bracket forward, it makes the turn signals visible from a good angle on the side, and also makes them level, as the base is actually slightly angled, so the lights would point somewhat upwards if they were on a level mounting.
I like how obvious they are, so people see them before they even blink - once it's blinking, they know exactly what it means. I think "hidden" lights still confuse people a bit.
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 03-21-2013, 06:38 AM   #8
springerpete
springerpete's Avatar
I used a pair of repro '32 Ford sidelights by making my own brackets to fit on the bumber braces. The lenses are the same pattern as my '29 headlights. Look very "period."
springerpete is offline   Reply With Quote
Old 03-21-2013, 08:12 AM   #9
jkcrosson
jkcrosson's Avatar
Thanks 31, Allan and Pete. Pete do you have any pictures?
Jamie Crosson
1929 Tudor
Old 03-21-2013, 08:19 AM   #10
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
How about using a socket in the headlight bucket? My A came with two-bulb headlights. The second socket was two contact socket. I wired my turn signals so that the brighter of the two filaments was for the turn signal, the lower as the park light. Works very well, visible even when the headlights are on, equally to most modern cars where the turn signal light is right next to the headlight.
See the TechTopics on my club's website (url below).
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 03-21-2013, 08:43 AM   #11
1931 flamingo
1931 flamingo's Avatar
Ck my avitar, I used Ford fog lights, wired intyo a signal stat in the front, custom brkts , you can't miss them when signaling for a turn, used the between the bumper bar ones in the rear.
Paul in CT
Old 03-21-2013, 09:05 AM   #12
Patrick L.
Patrick L.'s Avatar
I just use the lights on the vehicle. The front parking lights along with the cowl lights and the rear brake lights which are just run thru a signalstat.
Old 03-21-2013, 10:06 AM   #13
CarlG
CarlG's Avatar
I use the cowl lights for turn and park (dual filament bulb), and the brake lights on the rear. And like Patrick (above) powered by a Signalstat 900.
One of the guys in our club got some turn signal fixtures at the Harley shop. They are a tear drop shape, mounted them on the headlight bar. Look pretty nifty.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-21-2013, 11:08 AM   #14
Sparky
Sparky's Avatar
Here are mine. They are Harley Davidson turn signals with clear lenses and amber bulbs. They have a bullet shape which matches the headlights pretty well. I got these cheap on eBay.
Not the best picture, sorry.
Sparky is offline   Reply With Quote
Old 03-21-2013, 11:48 AM   #15
Art Bjornestad
Art Bjornestad's Avatar
I also used the 2 bulb reflectors and a brake light bulb. Very bright and you can't miss them.
Art Bjornestad is offline   Reply With Quote
Old 03-21-2013, 03:03 PM   #16
Jazzjr
Jazzjr's Avatar
I have seen these Beehive Clearance Lights used, change the bulbs to 6 volt, they can be purchased at almost any automotive shop, for $5.00 ea. Just paint the bracket black, and mount in the front splash apron holes. You can fit on Clear Lenses if you don't want Amber.
Jazzjr is offline   Reply With Quote
Old 03-21-2013, 03:21 PM   #17
steve s
steve s's Avatar
Here's what my dad used back in the day - 1939. Don't know what they're from
Here's what he used 22 years later--taken from a junkyard VW.
steve s is offline   Reply With Quote
