Old 03-18-2013, 01:42 PM   #1
ivoryjohn
ivoryjohn's Avatar
Default Need a Mascot Cast
I used to do jewelry work in college and art later. I've Now done a mascot of my springer in wax would like my noble dog immortalized on my model A radiator cap.
Does anyone know a Barn member or firm that will do one off castings or a small number in the pewter like substance of which the Ouails made. I have checked net and haven't been successful.
ivoryjohn is offline   Reply With Quote
Old 03-18-2013, 02:29 PM   #2
Big John
Default Re: Need a Mascot Cast
try; americanarrowcorp.com Maybe they can help...
Big John is offline   Reply With Quote
Old 03-18-2013, 02:53 PM   #3
lance leblanc
lance leblanc's Avatar
I will be following this thread.
I have often wanted to do the same thing but my priorities are that I should get my car back on the road again before I start such a project.
Never the less try these guys, not to far from you in St. Francisville LA
http://www.howellfoundry.com/
Lance
"When Solomon said there was a time and place for everything he had not encountered the problem of parking his automobile." Bob Edwards
lance leblanc is offline   Reply With Quote
Old 03-18-2013, 02:53 PM   #4
peters180a/170b
peters180a/170b's Avatar
Not in pewter but in Stainless steel... Every year at HERSHEY there is a small company that does such work. Door handles, mascots , radiator caps ..A friend of mine had a rare right side tail light bracket for this 1933 Buick done. Someone might know the company or has A vendors list for Hershey.They did do a Quail but it came out a little smaller.
peters180a/170b is offline   Reply With Quote
Old 03-18-2013, 03:02 PM   #5
Hicktick
Hicktick's Avatar
I recall reading threads about casting some parts that several guys were doing , but after some thought I think it was on the HAMB .
You might ask over there if anyone could cast you some .
Hicktick is offline   Reply With Quote
Old 03-18-2013, 03:22 PM   #6
FL&WVMIKE
FL&WVMIKE's Avatar
You might think of having it done on a 3-D Printer. It will turn out in a plastic material. You could then paint it to match your dog.
They details are very intricate. A copy of a monkey wrench, actually works.
You might GOOGLE to find someone, who does it commercially.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 03-18-2013, 03:31 PM   #7
Hicktick
Hicktick's Avatar
I went to the HAMB to look and I searched ,,,,,casting sand ,,,and I found lots of threads on making small parts and ornaments.
Try it
Old 03-18-2013, 03:32 PM   #8
Vic in E-TN
There is usually a company with a table at Chickasha. I do not remember their name but recall that they are from Washington. I can pick up a card this week and let you know.
Vic
Vic in E-TN is offline   Reply With Quote
Old 03-18-2013, 04:36 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Still lookin' for a pewter/chrome RAT TERRIER! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-18-2013, 05:18 PM   #10
CarlG
CarlG's Avatar
Buster T would be so proud sitting on your radiator cap!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-18-2013, 05:50 PM   #11
1931 flamingo
1931 flamingo's Avatar
You might try O'Brien Truckers, they adv in Street Rodder mag.
Paul in CT
Old 03-18-2013, 06:22 PM   #12
BILL WILLIAMSON
He deserves it, Carl, he "saved" my life!! Bill W.
Old 03-18-2013, 06:25 PM   #13
Phred
Phred's Avatar
How about this?
the rare dachshund mascot
Phred is offline   Reply With Quote
Old 03-18-2013, 09:28 PM   #14
BILL WILLIAMSON
Originally Posted by Phred View Post
How about this?
Thanks, Phred, but the ears ain't just right! LOL Bill W.
Old 03-18-2013, 09:35 PM   #15
FL&WVMIKE
FL&WVMIKE's Avatar
Phred ...............
I like your car. Sure would like to see it up close.
MIKE
Old 03-18-2013, 11:40 PM   #16
MikeK
MikeK's Avatar
I take it you are somewhat familiar with the process of lost wax casting. I made lost wax and investment castings for many years. If I were you I certainly would not want to commit my original sculpted wax to an unknown founder. As you know, one chance and it is gone ('lost'). I would seriously consider making a polymer mold from the original and injection molding multiple waxes first, using a suitable casting (not carving) wax. Multiples could easily be tree'd.
Original quails were not pewter. They were low air-pressure cast in a Zinc alloy using metal molds, similar to the process used for cast aluminum pistons. Some of the Zinc alloys ('pot metal') can also be cast in reusable high-temp silicone rubber molds, but they are very difficult to work in gypsum based lost wax molds for reasons I won't elaborate on.
For material I certainly would also avoid stainless for several reasons- Highest shrinkage rate, 1/4 to 5/16" per foot, expensive as it requires a shop with induction melting equip, and not as easily worked post-cast as copper based alloys. If you want a direct-to-white alloy that can be mass-media finished and polished, I'd go with a white brass like CA#997 (a.k.a. White Thombasil) or CA#9975 (Higher Manganese) or a German (20% Nickel) silver alloy like CA#976, sometimes referred to as 'dairy bronze'. If you later decide you want an overplate like Nickel, Gold, or Chrome it is easy on these alloys. If you know you are going to plate, just use an 80-20 red tin bronze. Plating stainless steel is a problem, as it requires passivating to remove the bonded surface oxygen.
As for a source to do the work, You really need to search 'art foundries' rather than industrial. Here's one:
LINK
MikeK is offline   Reply With Quote
Old 03-19-2013, 11:44 AM   #17
ivoryjohn
ivoryjohn's Avatar
Here is one picture of the wax so far. The specks are packing foam that are attracted to the wax for some reason
Looks bigger than it is
Old 03-19-2013, 11:57 AM   #18
gweilbaker
gweilbaker's Avatar
There was a guy in AZ that use to frequent the board that cast a bunch of stuff and sold as jewelry like zenith carb and such. He made a chicken COUPE. Does anybody remember? If I recall he was restoring a crate A maybe.
gweilbaker is offline   Reply With Quote
Old 03-19-2013, 01:49 PM   #19
ivoryjohn
ivoryjohn's Avatar
Clyde Ross Morgan does some terrific work and has a web site easy to find by name. Model A sculptures that look like die cast in bronze
Old 03-20-2013, 07:52 AM   #20
Ron Lowe
Hey Bill, Glad to finally see a photo of your friend, Buster T
Ron Lowe is offline   Reply With Quote
