Old 07-15-2025, 06:35 AM   #21
411Ton
Default Re: 16" Wide 5 drum replacement
fordy, you have this drum for my 3/4 ton?
411Ton is offline   Reply With Quote
Old 07-16-2025, 09:11 PM   #22
fordyford
fordyford's Avatar
Yes. I sent a PM
Keith
fordyford is offline   Reply With Quote
Old 07-20-2025, 10:22 AM   #23
40ford
40ford's Avatar
There are two NOS drums for sale on Early Ford V8 Club site.
https://www.earlyfordv8.org/classifi...Parts&id=20715
40ford is offline   Reply With Quote
Old 10-06-2025, 09:41 AM   #24
411Ton
in prep for Hershey this week, I retook some photos of the rear wide 5 drum/hub assy. I didn't realize that the two sides were different. Does anyone know which one is original? On the smooth one (without the ribs) I took a pic of stampings. My AI research seems to indicate that the stamped one is a replacement, although I'm not certain of this. I also saw a post in this string that said that the ribs were on passenger cars? The front and rear are both 12" diameter with 2" face.
Old 10-06-2025, 10:33 AM   #25
petehoovie
petehoovie's Avatar
Old 10-06-2025, 10:41 AM   #26
411Ton
@38Coupe, you mentioned you have a rear axle?
Old 10-06-2025, 12:26 PM   #27
411Ton
petehoovie, did you have a reply? if so, I can only see the reprint of my comments/photos
Old 10-07-2025, 05:10 AM   #28
38 coupe
38 coupe's Avatar
I have a complete rear axle, drum to drum, from a 41 3/4 ton. It will probably be a couple weeks before I get back to it, PM me for more information.
Old 10-07-2025, 08:28 AM   #29
51504bat
51504bat's Avatar
Pete, as usual, is just helping us old farts with less than optimal vision by enlarging the photo you posted.
Old 10-08-2025, 06:00 AM   #30
Bruce of MN
Bruce of MN's Avatar
This shows swaging for Model As, probably very similar for newer Fords.
https://www.fordgarage.com/pages/swaging.htm
I have used a holesaw for cutting the old stud.
Bruce of MN is offline   Reply With Quote
Old 10-08-2025, 08:56 AM   #31
GB SISSON
GB SISSON's Avatar
The link above takes us to an extremely well done tutorial on how all of this brake drum stud swaging is done, along with removal of old studs. The photos are excellent and make the text easy to understand. As long as there is an internet, this type of learning tool will be easily passed down to future ford lovers.
Old 10-09-2025, 08:32 AM   #32
51504bat
51504bat's Avatar
And we can thank Al Gore, correct? Oops, too political. This will probably get deleted. Hope it won't get me banned.
Old 10-13-2025, 10:11 PM   #33
411Ton
I really appreciate all the help and support everyone here provides! I was very fortunate, and found 4 NOS 12" drums for $150 at Hershey. Grabbed them up quickly! Thanks for the swaging link too, will read and heed!
Old 10-14-2025, 06:39 AM   #34
L-head
You will still need the correct studs for the rear hubs. The "Green" Ford parts book will have the correct part number; it is 91D-XXXX for the 3/4 ton 122" trucks. Be patient, they can be hard to find.
L-head is offline   Reply With Quote
