#21 |
Probably fit the early short snout crankshafts
#22 |
I think the yellow tag on it says model A & B. Hard to read in my pic here....but click on the earlier post and it enlarges it.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#23 |
#24 |
You guys do realize its really not possible to remove the crank gear while the crank is in the block. I'm wondering what your thinking?
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#25 |
I was thinking for the ones that are "stuck" on the crank. I have a really good four jaw puller that I normally use and I got caught up in the moment of having a "Ford" tool. If I took a second to think about it, I wouldn't have bought it
#26 | |
#27 |
Maybe weld a couple nuts on there and pull it off ? Still gotta remember when driving the new one on you will be driving against the thrust face of the bearing.
#28 | |
I welded two bolts head first to a crank gear with no rear access (diesel engine at work) and pulled it easily with a common puller. The new one will slip right on if it's heated to approx 400 degrees. (no, the tempering will not be affected).
