Old 08-02-2022, 03:14 AM   #21
ssffnomad
ssffnomad's Avatar
Default Re: removal of painted pin-striping
Post #15 . Why take the risk ? It looks great
Worry less.
Drive more
Stretch
ssffnomad is offline   Reply With Quote
Old 08-02-2022, 01:40 PM   #22
petehoovie
petehoovie's Avatar
Originally Posted by 47topless View Post
Is there a way to remove just the pin-striping?
The wife just does not like it and that is important (duh!) of course.
Thank you,
PhilAttachment 495880
https://www.youtube.com/watch?v=OQBcGUivPuY
Old 08-02-2022, 01:47 PM   #23
hotrodart
hotrodart's Avatar
The paint under the stripes will most likely be close to the original shade of black, whereas the rest of the car most likely has faded a bit over time........you will still see the ghosts of the stripes.
hotrodart is offline   Reply With Quote
Old 08-02-2022, 03:32 PM   #24
Joe Shell
Sounds like you have a very sad situation to deal with.
Good luck!
Joe
Joe Shell is offline   Reply With Quote
Old 08-02-2022, 03:38 PM   #25
Joe Shell
Good luck!
Joe
Old 08-02-2022, 04:28 PM   #26
cmbrucew
cmbrucew's Avatar
Maybe less grief to sell the car, and let her buy one she likes.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 08-06-2022, 11:58 AM   #27
47topless
47topless's Avatar
Thank you all for the responses. My wife is not able to ride in the car anymore but she does enjoy looking at it.
I will try the easy off technique. Thank you V8coopman for the excellent instructions.
I will post the results.
Phil
47topless is offline   Reply With Quote
Old 08-06-2022, 06:21 PM   #28
B-O-B
B-O-B's Avatar
my wife did mine for me.
B-O-B is offline   Reply With Quote
Old 08-06-2022, 06:31 PM   #29
petehoovie
petehoovie's Avatar
Old 08-07-2022, 11:09 AM   #30
rotorwrench
rotorwrench's Avatar
I've read an article or two about the restoration teams at the Smithsonian Paul Garber restoration facility slowly hand sanding aircraft down one coat at a time to look for original paint colors and markings that may be hidden under subsequent coats of paint. It is a long and tedious process but the only way to verify what's there.
Clear coat 2-stage is easy to color sand but single stage can be color sanded and coated with clear as well. A lot depends on how thick the top coat is and it's current condition. Pin stripes put on with a brush can be fairly thick but they stand proud of the base coat so it can be done if a person is careful but it will take a good bit of time. Fingers will be very smooth after that much hand sanding.
Old 08-08-2022, 02:17 PM   #31
Mart
Mart's Avatar
Probably best to just say sorry, it's too risky to try and remove them. Like it or lump it.
Mart is online now   Reply With Quote
Old 08-08-2022, 04:12 PM   #32
oldford2
oldford2's Avatar
I would mask it and carefully air brush the body color over the striping. Or use a wider brush and hand paint over it. Not rocket science.
Always keep the Missus happy and she will make you happy.
John
And by the way, I agree with your wife
oldford2 is offline   Reply With Quote
Old 08-08-2022, 06:10 PM   #33
47topless
47topless's Avatar
Now this makes so much sense. Would the average person notice a black car with black pin striping? If they did, and asked me about it, I would tell them it cost a lot more, but we think it was worth it.
Thank you oldford2
Old 08-09-2022, 01:15 PM   #34
rotorwrench
Black shows everything. Even if its black on black it will still be noticeable to the trained eye.
Old 08-09-2022, 02:05 PM   #35
Lanny
Lanny's Avatar
47topless (Phil) says if someone see's it, he has it all figured out, that
If they asked me about it, I would tell them it cost a lot more, but we think
it was worth it... Sounds like Phil has the answer to his stripe problem.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
