#21 |
Post #15 . Why take the risk ? It looks great
Worry less. Drive more Stretch |
#22 | |
#23 |
The paint under the stripes will most likely be close to the original shade of black, whereas the rest of the car most likely has faded a bit over time........you will still see the ghosts of the stripes.
#24 |
Sounds like you have a very sad situation to deal with.
Good luck! Joe |
#25 |
Good luck! Joe |
#26 |
Bruce
Works good Lasts long time |
#27 |
Thank you all for the responses. My wife is not able to ride in the car anymore but she does enjoy looking at it.
I will try the easy off technique. Thank you V8coopman for the excellent instructions. I will post the results. Phil |
#28 |
my wife did mine for me.
#29 |
#30 |
I've read an article or two about the restoration teams at the Smithsonian Paul Garber restoration facility slowly hand sanding aircraft down one coat at a time to look for original paint colors and markings that may be hidden under subsequent coats of paint. It is a long and tedious process but the only way to verify what's there.
Clear coat 2-stage is easy to color sand but single stage can be color sanded and coated with clear as well. A lot depends on how thick the top coat is and it's current condition. Pin stripes put on with a brush can be fairly thick but they stand proud of the base coat so it can be done if a person is careful but it will take a good bit of time. Fingers will be very smooth after that much hand sanding. |
#31 |
Probably best to just say sorry, it's too risky to try and remove them. Like it or lump it.
#32 |
I would mask it and carefully air brush the body color over the striping. Or use a wider brush and hand paint over it. Not rocket science.
Always keep the Missus happy and she will make you happy. John And by the way, I agree with your wife Last edited by oldford2; 08-08-2022 at 04:17 PM. |
#33 |
Now this makes so much sense. Would the average person notice a black car with black pin striping? If they did, and asked me about it, I would tell them it cost a lot more, but we think it was worth it.
Thank you oldford2 |
#34 |
Black shows everything. Even if its black on black it will still be noticeable to the trained eye.
#35 | |
47topless (Phil) says if someone see's it, he has it all figured out, that If they asked me about it, I would tell them it cost a lot more, but we think it was worth it... Sounds like Phil has the answer to his stripe problem. ![]() .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
