Old 08-01-2022, 06:24 PM   #1
47topless
47topless's Avatar
Default removal of painted pin-striping
Is there a way to remove just the pin-striping?
The wife just does not like it and that is important (duh!) of course.
Thank you,
47topless is offline   Reply With Quote
Old 08-01-2022, 06:34 PM   #2
ford38v8
ford38v8's Avatar
Default Re: removal of painted pin-striping
Try telling the wife you don't like how she puts on her lipstick.
Alan
Old 08-01-2022, 06:46 PM   #3
Lawson Cox
Lawson Cox's Avatar
I love it Alan, but I'd not advise a guy to do that, not ever.
Old 08-01-2022, 07:22 PM   #4
cas3
Who's car is it ?
Old 08-01-2022, 07:38 PM   #5
paul2748
paul2748's Avatar
If my wife said that, I would "too Bad I do". Man Up
48 Ford Conv
56 Tbird
54 Ford Victoria
paul2748 is online now   Reply With Quote
Old 08-01-2022, 07:43 PM   #6
cmbrucew
cmbrucew's Avatar
Phil
Ask the striper that did it.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 08-01-2022, 09:10 PM   #7
ssffnomad
ssffnomad's Avatar
I would not even think about removing, unless you sending out for new paint.
BTW, it looks great . Hint ��
Stretch
ssffnomad is offline   Reply With Quote
Old 08-01-2022, 09:12 PM   #8
Blindhuckster
Blindhuckster's Avatar
The local well-known pin stripper, Bob Bonds who has been doing pinstripes and artwork for decades told me to use easy off oven cleaner in the yellow can, to remove pinstripes. If you do a google search you will find several youtube video's about the process.
Blindhuckster is offline   Reply With Quote
Old 08-01-2022, 09:13 PM   #9
J Franklin
J Franklin's Avatar
Use a quart of paint remover and buy a gallon of body color!
Old 08-01-2022, 09:16 PM   #10
petehoovie
petehoovie's Avatar
Ask her if she will come up with the $20K to repaint the car after you screw it up...
Old 08-01-2022, 09:24 PM   #11
3quarter32
3quarter32's Avatar
I have used Easy Off on stripes before. Do not let it set to long as I did. It cleaned the stripes, paint under it, and softened the primer.
3quarter32 is offline   Reply With Quote
Old 08-01-2022, 09:29 PM   #12
Digger
Digger's Avatar
Are the stripes painted on clear coat or single stage paint? Makes a huge difference. If it’s on clear coat, you can use 3000 grit or so, and color sand it away, then buff out the area, I have done that before on large logos painted on the doors on a ‘33 pick up I had.
Digger is offline   Reply With Quote
Old 08-01-2022, 11:05 PM   #13
cas3
Digger is correct, the way to do it would be to carefully sand it off by hand, without going too deep, and then hand buff without rubbing thru any where. Almost like you walking the tight wire at the circus for the first time, no room for error.
Old 08-01-2022, 11:19 PM   #14
Lanny
Lanny's Avatar
[QUOTE=cmbrucew;2153513]<-------
He will know what kind of paints were used and if they can safely be removed.
cmbrucew has the CORRECT answer.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 08-01-2022, 11:41 PM   #15
ssffnomad
ssffnomad's Avatar
Why , take th RISK �� ?
Old 08-01-2022, 11:42 PM   #16
Detonator
Detonator's Avatar
I used the Easy-Off method to remove poorly-executed door signs on my roadster pickup. They were done in One-Shot over single-stage Delstar. Took awhile, but it worked well and left no discoloration or residue. I'd guess your striping is done in One-Shot as well.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 08-01-2022, 11:43 PM   #17
cas3
If you bought a car that was already painted, how many could tell you who painted it?
Old 08-01-2022, 11:51 PM   #18
Lanny
Lanny's Avatar
cas, hopefully the person or dealer you bought it from could tell you
who painted it.
AND if you can't find out good info about the paint on it, then be
very careful about applying any Chemicals on it, or the stripe.
Old 08-02-2022, 12:13 AM   #19
V8COOPMAN
V8COOPMAN's Avatar
I've used the "Easy-Off" oven cleaner in the YELLOW spray can....GOTTA be the YELLOW can! I shake it well and spray a small amount of the oven cleaner liquid into the spray cap (or some other SMALL receptacle). FIRST....Try to remove a test stripe in an inconspicuous spot.
In the shade, have some water in a bucket, with a T-shirt or similar rag. With the rag dampened, rub it on the surface where the unwanted pinstriping is. Take a "Q-Tip" and stick the cotton end in the bucket to saturate the cotton with water. Now, dip the cotton end into your capful of "Easy-Off". Rub the Easy-Off directly onto about one foot worth of the unwanted pin stripe with a back & forth motion. Make sure to keep the cotton swab well-dipped in the Easy-Off. You ought to get 6" or so out of each dip. Walk away and take a short cigarette break....3 to 4 minutes or so. Come back with the wet rag and begin wiping the Easy-Off and pinstripe off of the surface. It should all come off the first try. If not, extend your cigarette break by a minute or two. Use a very wet rag.
You'll be left with a somewhat dulled line on the painted surface where the stripe used to be. Throw some polish at it, and it's like it never was striped. All that most stripers ever use is "1 SHOT" sign painters' ENAMEL.
Click Links Below __
T5 W/TORQUE TUBE
Old 08-02-2022, 01:03 AM   #20
cas3
All very good coop man, unless its been clear coated. I'd tell the wife to ride with someone else
