Old 09-24-2024, 08:12 PM   #21
Oldcarbearings
Location: North Warrandyte, Melbourne,Victoria, Australia
Default Re: Transmission Roller Bearings
We've supplied recently to a member on this forum group here in Australia euro brand Baltzer&UK brand Pollard (UK used to be a part of Hoffman/R&M bearings) &Blackwell,
The NEW Baltzer's are made in china as is Kobe brand the original HYATT type with the spiral grooves are next to impossible for us to procure&source&supply from overseas,RBC NO LONGER make these wound journal roller bearings same applies to BOWER who USED to make them in MEXICO &then china BEWARE of the Snyder's ones for the $ they can't possibly be made in the USA for the $ they&other know USA FORD parts vendors sell them for......
Oldcarbearings is offline   Reply With Quote
Old 09-24-2024, 08:35 PM   #22
Synchro909
Synchro909's Avatar
FWIW, I think we are talking at crossed purposes. This thread is about the roller bearings in the gearbox. It seems to me that you are talking about the rear wheel bearings.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 09-24-2024, 08:49 PM   #23
Oldcarbearings
Originally Posted by updraught View Post
https://www.snydersantiqueauto.com/P...ission-3-speed
Looks like a Chinese one to me by the price.
I'd do my own research on that ...
Absolutely, definitely,positively 100% NO WAY these are anything but made in china (KOBE brand) or Baltzer chinese made , i can't fathom, get it /understand WHY ALL of the FORD spare parts " vendors" DON'T ALL approach BOWER/RBC to start making them in THE USA again?!!!!!!.SURELY there's enough of them (FORD spare parts vendors) , that if all grouped together could afford to get these remade?......, beggars belief sigh .
Old 09-24-2024, 08:52 PM   #24
Oldcarbearings
No i'm talking about the wound journal roller bearings,BUT the OP'S thread isn't about the transmission but rather the CWP front or rear bearings,
Which are a combination/mixture of wound journal roller &sleeve &tapered roller bearings.IF the problem's in the prop/tail shaft then it's a wound journal roller bearing or ball bearing &housing SOME Ford's used a wound journal roller bearing in a rubber housing.
Old 09-24-2024, 08:56 PM   #25
Oldcarbearings
What model/year Ford is yours Rob?,
Are you talking about the CWP (crown wheel pinion) front or rear bearings?,
These are TIMKEN tapered roller type that fit/sit inside a double cup,&the cones fit/sit inside this cup either end,or is it a wound journal roller bearing type?,
FORD used a combination/mix of both in the pinion &differential.
Old 09-24-2024, 10:08 PM   #26
Benson
iN POST #19 I am speaking about transmission bearings A-7118 and A-7121.
THESE ARE HYATT BEARINGS (SPIRAL WOUND TYPE).
They are stamped as BOTH "Hyatt" and Bower.
EDITED: BOWER added 09-27-24
These were made by Hyatt and others. Maybe someone knows which companies made them for Ford besides Hyatt.
The defective Rear wheel bearings mentioned above are well known as defective and that is another story.
Many of the OEM rear wheel bearings Ford supplied were spiral wound Hyatt bearings as far as I know.
I have seen wheel bearings AND transmission bearings made by Hyatt.
Benson is offline   Reply With Quote
Old 09-25-2024, 03:30 PM   #27
ModelA29
ModelA29's Avatar
Originally Posted by old ugly View Post
someone should write a book on good and bad, use/don't use parts and the places to source the good stuff. on all different types of parts.
Problem is the guys selling the junk will have their lawyers sue you for ruining their business.
ModelA29 is offline   Reply With Quote
