Old 09-28-2021, 05:27 PM   #1
chrs1961815
chrs1961815's Avatar
Default Transmission Roller Bearings
Just had my roller bearings fail - where can I get a good quality set unlike the problematic offshore ones?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 09-28-2021, 07:14 PM   #2
old ugly
old ugly's Avatar
Default Re: Transmission Roller Bearings
i think if you can find some original ones in good condition. but i took 6 transmissions apart just to get 3 good bearings.
i would like to know what you come up with in your search.
someone should write a book on good and bad, use/don't use parts and the places to source the good stuff. on all different types of parts.
i am a believer that not all off shore parts are junk, but is always a gamble. the suppliers get in junk and try to sell it as quality and now we just have this bad taste in our mouths.
ou
old ugly is offline   Reply With Quote
Old 09-28-2021, 07:27 PM   #3
Ruth
When this first came to light a while back Bert's had some of the good ones. I have a set in my 'spare' transmission, but I'm sure Steve is long out of them by now. You may check tho.
I wonder what Steve Mitchell is using in his synchro transmissions??
Ruth
Old 09-28-2021, 07:52 PM   #4
Tacoma Bob
Tacoma Bob's Avatar
I just ordered a Mitchell syncro trans last week and asked Steve what he is using. He informed me that Snyder's is currently having bearings produced here in the States. Those are what Mitchell is using.
Tacoma Bob is offline   Reply With Quote
Old 09-28-2021, 07:58 PM   #5
chrs1961815
Well now I think it is the rear end or u joint, but I do still want to know this.
Old 09-28-2021, 08:03 PM   #6
Tom Endy
Tom Endy's Avatar
The only way you can get some reliable roller bearings for a Model A transmission is to salvage them out of a Model A transmission that has serviceable bearings in them. Pick them up at swap meets. None of the suppliers seem to be able to do anything about this situation.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 09-28-2021, 11:04 PM   #7
Synchro909
Synchro909's Avatar
Tom Endy
A while back, it was impossible to get a decent tube. I won't blame the Chinese because no matter where they were made, they were rubbish made out of recycled materials. IMO, the ones made in Europe were the worst. I think it was Brattons who had some made from virgin materials and they were good. They did quite nicely out of them till others found they couldn't sell their rubbish so they started supplying better ones. Let's hope the same thing happens with these bearings and a few other notoriously poor repro parts.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 09-29-2021, 09:59 AM   #8
Russ/40
Russ/40's Avatar
What is the min / max price the market will bear for these bearings? I have a machinist who could produce these in quantity. What is the Rockwell hardness necessary?
Russ/40 is offline   Reply With Quote
Old 09-29-2021, 10:31 AM   #9
JKY
He's out. I called a year ago and he didn't have them any longer, can't find any more.
JKY is offline   Reply With Quote
Old 09-29-2021, 10:49 AM   #10
Ruth
Russ, I think Bert's was asking $20 each when I bought them. I would probably have paid more to get my car back on the road and have the peace of mind my transmission that I just installed ~$800 worth of parts in would hold together.
DANG!!! Was it that long ago already!!
Ruth
Old 09-29-2021, 02:56 PM   #11
Pete W.
How did you discover the roller bearings were going bad?
Grinding? Shifting problems? Noise? I'm having sudden issues with grinding while shifting into second and into third at about 25,000 miles after a rebuild.
Pete W. is offline   Reply With Quote
Old 09-29-2021, 05:51 PM   #12
chrs1961815
As I said in an earlier post, it has turned out to be the rear end so I can't really answer that question. Something in the back of the drive train can amazingly sound like it is in the trans.
Old 09-30-2021, 03:45 PM   #13
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Sometimes you have to read the whole thread as well!
See post 4
Old 10-01-2021, 05:25 AM   #14
updraught
updraught's Avatar
See post 4
https://www.snydersantiqueauto.com/P...ission-3-speed
Looks like a Chinese one to me by the price.
I'd do my own research on that ...
updraught is offline   Reply With Quote
Old 10-01-2021, 10:41 AM   #15
rotorwrench
rotorwrench's Avatar
Another person to check with is Mac at VanPelt Sales. The model A transmission roller bearing types were carried over into the V8 era light duty 3-speed transmissions under part numbers B-7118-A and B-7121-A for those folks that may need them.
Mr. VanPelt's business is transmissions and I'm sure he would steer a person toward the best possible replacement parts for these bearings. He may not work on a lot of model A gear boxes but he likely does now and then. If nothing else, a good set may be found in a later Ford light duty 3-speed transmission as well.
Old 12-02-2021, 01:59 PM   #16
pat in Santa Cruz
pat in Santa Cruz's Avatar
I recently went through roller bearing failure for the third time. It seems they last 30,000+ to 40,000 miles, which means removing the transmission every 30K just to replace them, hopefully pre-emptively. That's a lot of work for a $10 bearing. These were the type with an axle that seats in a hole, not the dimpled type which fail in 300 miles. Nevertheless, even these repros only last apparently 30K miles, unlike original Ford bearings which usually outlast some engine components. In the past I've seen these thin, flimsy cages fail and get wrapped around the rollers. This time three rollers came out of the short bearing cage when the tips wore off, and the spacer wore into the cage of the long bearing, releasing three of the rollers in that one. Then one or more of them ground up the cluster shaft (a new repro) which gives me pause about the correct Rockwell hardness of these repro shafts. When the cluster dropped down, it unevenly ground the teeth on the drive gear, ruining it and a recently bought MARK cluster gear. Not an inexpensive repair nor is it the easiest job on a Model A. Meanwhile, I rebuilt the transmission with some beautiful original Ford rollers I happened to find in a gearbox I disassembled to send off to Mitchell for conversion to syncro. It sure would be nice to be able to buy reliable gears made to original specs. I would pay quite a bit more for a well made bearing to avoid costs like this every 30K miles.
pat in Santa Cruz is offline   Reply With Quote
Old 12-02-2021, 03:57 PM   #17
Synchro909
Synchro909's Avatar
I can't for the life of me understand why people think they are saving money by buying those (or any) cheap components. For the sake of a very few dollars, they put in junk bearings, hen have to do the whole thing again when they fail. That's the very definition of false economy IMO.
The price of quality is long forgotten by the time it wears out.
I might make that a future signature line!!
Old 12-02-2021, 04:29 PM   #18
Ruth
I wonder what bearing Mitchell is using if the "good" bearings are not available? Or does their transmission use a different bearing??
Ruth
Old 09-24-2024, 01:56 PM   #19
Benson
Now that it has been 3 years since this thread was posted does anyone have high mileage on the "Improved " bearings?
I went through 15 or 20 old used transmission bearings made by Hyatt (the "spiral" roller type). These bearings apear to still be good. That is I have not seen any of the Hyatt bearings which failed.
ADDITIONAL INFO: As mentioned in post #26 these bearings mentioned in this post are transmission bearings. A-7118 and A-7121.
By the way I went through 15 or 20 [B]old stock "Dimple" style mentioned in post #16 which makes me wonder if the problem is with the quality of steel used and NOT the design of bearings.
I have seen quite a few of the type with "pins and holes in the cages" fail BEFORE the improved bearings went into production.
Benson is offline   Reply With Quote
Old 09-24-2024, 02:13 PM   #20
Rob Doe
For what it is worth, I installed all new bearings from Snyder's into our overhauled transmission last fall. The roller bearings were not the dimple design that was notoriously failing. The bearings and all the remaining new transmission parts now have nearly 6000 miles on them with no issues. W600 as sold by the vendor's has been used during that time. I'll report back on any failures.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
