Old 06-02-2010, 09:30 PM   #21
~~Walts37~~
~~Walts37~~'s Avatar
Default Re: George "Skip" Haney Water pumps
If I ever have a overheat problem I may send them to skip but the ones I got from Macs for my 59 ab have been doing a perfect job for me for the last 4 years. (Fingers crossed) ~~Walts37~~
~~Walts37~~ is offline   Reply With Quote
Old 06-02-2010, 10:15 PM   #22
Bassman/NZ
Bassman/NZ's Avatar
What sort of $$$ (ballpark)??
Bassman/NZ is offline   Reply With Quote
Old 06-03-2010, 06:34 AM   #23
jimTN
I have one of skips overflow valves on my 32 Ford and 29 Packard, they work great and solved the overflow problem.
jimTN is offline   Reply With Quote
Old 06-03-2010, 08:00 PM   #24
Bassman/NZ
Bassman/NZ's Avatar
Not trying to start a riot, but how do Speedway and Drakes pumps compare to Skips? The reason I ask is they are both already available here in New Zealand.
Old 06-04-2010, 07:33 AM   #25
39portlander
39portlander's Avatar
Bassman, I had THE Walt Dupont rebuild my 59AB, the drake pumps I had were off a 1/2 hole to bolt on the block. We shipped my originals to skip and a week later they were back!! I've since returned the drake pumps, when I find a decent orig. pair of pumps I will send those out for a future motor. Listening to folk's on the barn, not much beat the original part. Drake has fixed the prob. W/the pumps. They were great to deal with!!
39portlander is offline   Reply With Quote
Old 06-04-2010, 11:21 AM   #26
Ford46
Ford46's Avatar
I've had Skip rebuild two coils and two distributors (I always carry a spare, or in this case loaners). Very pleased with the quality and turn around time. LouB.
Ford46 is offline   Reply With Quote
Old 06-05-2010, 05:28 AM   #27
36 coupe
Banned
The Model A only overheated when we used it to power a cord wood saw.Lack of foward motion may have done it but a thermostat stopped the overheating.The Ford never overheated when worked in hot weather.A friends father ran a sawmill with an A engine until he bought a new tractor.There were 4 Model A powered cord wood saws cutting firewood in the early 60s near me.I helped Joe Ribero saw wood with his A powered saw in 1964.He told me me you had to use a thermostat to avoid boiling.
36 coupe is offline   Reply With Quote
Old 06-05-2010, 05:45 AM   #28
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
All 3 39 Fords has skip water pumps and his coils. Very happy with his work. Seen his shop and he enjoys his work very much.I got two waterpumps for the 35 to snd him for rebuild.Only place to go in my book.
Old Redneck is offline   Reply With Quote
Old 06-05-2010, 06:33 AM   #29
GaryTx
GaryTx's Avatar
The single biggest difference when starting your flathead is a coil rebuilt by Skip...He's the best...
GaryTx is offline   Reply With Quote
Old 06-05-2010, 08:37 AM   #30
G.M.
36 coupe, You just don't GET IT even after all these years. Number one an "A" motor isn't like a V/8 and never had over heating problems. The reason the "A" motor over heated was the water was pumped out the over flow and got REAL LOW on water and BOILED over. The thermostat RESTRICTED and SLOWED the flow of water with a LESS WATER LOST out the overflow BUT STILL LESS WATER THAN A FULL radiator. With a LITTLE MORE WATER in the system BUT STILL NOT FULL the engine RAN HOTTER THAN IT WOULD FULL OF WATER ALL THE TIME but did not boil over. If you had SKIPS PRESSURE VALVE it would have ran in the normal range and you could have SAWED WOOD ALL DAY without FOOLING AROUND with a hot engine. PLease read this several times and maybe you can understand it. This is the SAME THING that happens on the V/8s when MODERN thermostats are installed in temperatures over 85. Also you may want to read the PROVEN results from many others that use a WORKING pressure cap or Skips valve. One persons VISSIONS are no where equal to HUNDREDS of of reported feild results. Also the stock "A" pump provides plenty of cooling water flow and needs no improvement, where the stock 32 to 53 pumps do not provide enough flow. Your 36 pumps deliver 55 gallons each in 5 minutes where Skips 32 to 36 pumps deliver 92 gallons, again ask the several thousand users and get the REAL PROVEN results. G.M.
www.fordcollector.com
Old 06-05-2010, 09:21 AM   #31
WHITEY
WHITEY's Avatar
Ive only heard GOOD things about "SKIPs" pumps...
and now after reading this thread...
can confirm a bunch of others have have had good results...cool
WHITEY is offline   Reply With Quote
Old 06-05-2010, 12:49 PM   #32
Mike..Yorba Linda
Two pumps and a coil......fantastic....
Mike..Yorba Linda is offline   Reply With Quote
Old 06-05-2010, 04:51 PM   #33
Cecil/WV
Cecil/WV's Avatar
Six pumps and a coil, no complaints.
Cecil/WV is offline   Reply With Quote
Old 06-18-2010, 08:21 AM   #34
lucky
lucky's Avatar
I have a 38 cpe with a 53 engine and late truck waterpumps.
My question is your website shows modified impellers on the early engines, is this the case with the late truck pumps?
thanks, marvin
lucky is offline   Reply With Quote
Old 06-18-2010, 09:28 AM   #35
Cecil/WV
Cecil/WV's Avatar
Try [email protected]
Old 06-18-2010, 10:19 AM   #36
FL&WVMIKE
FL&WVMIKE's Avatar
Four pumps, two coils and two overflow kits here. Would I do it again ? You betcha !
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 06-18-2010, 12:47 PM   #37
mike in las vegas
mike in las vegas's Avatar
Got hot spark and a cool car thanks to Skip
mike in las vegas is offline   Reply With Quote
Old 02-21-2012, 07:29 PM   #38
foxydoxy
Hi... I am a Nu-bie here trying to get intouch with Skip Haney for a rebuild of two 1937 (60hp) waterpumps. Suggestions welcomed.... Mike
foxydoxy is offline   Reply With Quote
Old 02-21-2012, 08:01 PM   #39
CC33
CC33's Avatar
His email is listed in this thread.
CC33 is offline   Reply With Quote
Old 02-21-2012, 08:43 PM   #40
foxydoxy
Thanks...for the help....for some reason I am getting no responce...Mike
