Old 02-28-2017, 02:18 PM   #21
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: Looking for a little info 49 Pickup
The bottoms of my doors are horrible.
I try not to look too closely and just drive it.
1948F-1Pickup is offline   Reply With Quote
Old 02-28-2017, 02:28 PM   #22
Art Newland
Art Newland's Avatar
Originally Posted by mtflat View Post
There are a few of us here that focus on trucks. In my opinion, you'll get better info here than some other forums because there you have to sort out the real stuff from the junk that gets posted by guys who are in competition for post counts.
You got honest info on this thread...
Just beware, you buy one and others will follow it home!
I have a safety valve for such things... called a wife!
Art Newland is offline   Reply With Quote
Old 02-28-2017, 08:44 PM   #23
TJ
TJ's Avatar
Cab corners ,cowl panels, and the floor pans are the common rust area. If it has a heater(or had a heater) pay close attention to the passenger side floor pan.
Old 02-28-2017, 10:41 PM   #24
cmbrucew
cmbrucew's Avatar
Add to those, around the windshield, fender extensions, fenders where the running board attaches, and the running boards themselves. All good fun.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-01-2017, 11:58 PM   #25
mtflat
mtflat's Avatar
Yeah, I know what you mean, "the voice of reason".... hahaha
Rust out spots really depends on the area you buy your truck from. Mid-west and south can be really bad, north west US varies, southwest US is usually solid....
Most I've seen rust out where the lower valance meets the front fender extensions - below the headlight. The metal bed floor can rot depending on how the truck was cared for. Plus what the others have mentioned.
mtflat is offline   Reply With Quote
Old 03-02-2017, 06:05 PM   #26
FortyNiner
FortyNiner's Avatar
As others have mentioned, there are a couple of standard rust areas for the F1s. The fenders, in particular, are prone to rust where Ford designed in stiffeners that ensured a reliable rust breeding ground. Portions of the joint between the upper and lower front fenders, as well as any complicated bend area of the lowers. Running boards also had stiffeners - same story. The running board to fender joints, and often the rear fender to bed joint, are common trouble areas.
For the 53-56 trucks, the cab roof by the rain channel, the front of the hood, and the side cowls are watch areas.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 03-08-2017, 05:16 PM   #27
Art Newland
Went and took a good look at the 49 over the weekend. Gonna bring it home next weekend. Couldn't find any rust except for the drivers side floor boards. Should be an easy fix. The truck needs a lot of mechanical repair, no brakes at all, the wiring harness is a DIY setup that's in good shape but I'll want to put it back stock, has been converted to 12 volts however. The engine appeared to have a considerable amount of blow-by, my first flatty V8, I'll have lots of questions.
Old 03-08-2017, 07:29 PM   #28
1948F-1Pickup
Yup. That looks sharp.....
AFA answering questions, I only know a little from what I've gleaned owning mine for 1.5 years but I'm game.
Old 03-08-2017, 07:44 PM   #29
Ken Crans
Ken Crans's Avatar
Art,Here's cuz to your truck... Lot of F-1 guys and experts to answer all questions. Ken
Ken Crans is offline   Reply With Quote
Old 03-08-2017, 09:24 PM   #30
Art Newland
More like twins Ken! Is that red a factory color? Any fancy coolness under the hood? First thing I'll need to address is the brakes, that shouldn't be too big of a deal. The choke is very sticky, hard to push back in, and it acts as though the accelerator pump isn't working. After having it running for a while it appears an accumulation of oil gathered above the RHS head and started to smoke. Leaking from the intake manifold? Maybe?
Old 03-08-2017, 11:27 PM   #31
FortyNiner
FortyNiner's Avatar
Looks like a solid truck. If you don't already have one, a 49-52 Shop Manual is a good investment. They are available on Amazon/eBay for about $30, typically.
Old 03-08-2017, 11:37 PM   #32
Art Newland
Yes, got one of the paper versions on the way.
Old 03-09-2017, 12:56 AM   #33
37Benny
37Benny's Avatar
Does this mean you and I are going to be forming the North Cascade Chapter of the Early Ford V8 Club? Benny
1937 Ford 1 1/2 ton Deluxe Panel (78-80D)
1937 Ford Deluxe 4dr Touring Sdn (78-73D)
1928 Ford Model A Tudor Sdn (55-A)
1928 Ford Model A TBD
MTFCI & AACA
Tacoma Model T Club
Tyee Old Car Club
Gallopin Gertie Model A Club
37Benny is offline   Reply With Quote
Old 03-09-2017, 08:37 AM   #34
corvette8n
corvette8n's Avatar
Hey Art that is one nice looking truck, post some more pictures when you get it home. After you fix the safety issues, I would just drive it to see how the motor shakes out.
Old 03-09-2017, 12:56 PM   #35
Art Newland
Benny, you can not join or form any more clubs until you have a drive-able Model A.
Old 03-09-2017, 01:15 PM   #36
Art Newland
I think the pictures make it look a little nicer than it really is, but it's still pretty good. Way nicer than I expected to end up with. I think I'm better off having to fix mechanical things rather than patch rust outs. The engine didn't make any nasty sounds. I wonder if the oil leak could be back at the fuel pump? If the V8 is anything like the Model A, it can be pretty tired and still run pretty good. The accelerator pump probably has a check valve? Maybe it's just gunked up.
Old 03-09-2017, 03:54 PM   #37
37Benny
37Benny's Avatar
What?I thought you could be President and I'll be Newsletter Editor, Librarian, Historian, Facebook Group Administrator..we wouldn't need a Treasurer instead dues into the club are 12 self address stamped envelopes
to get the newsletter!...And how about this for a newsletter name?.."The V8 Courant"... nice find, welcome to the v8 brotherhood benny
MTFCI & AACA
Tacoma Model T Club
Tyee Old Car Club
Old 03-11-2017, 11:38 PM   #38
Art Newland
Nothing like moving an old pickup with no brakes, in the pouring down rain...
Old 03-11-2017, 11:39 PM   #39
Art Newland
https://www.youtube.com/watch?v=bLAU...ature=youtu.be
Old 03-13-2017, 01:13 AM   #40
Art Newland
Spent some time getting the truck running a little better. Pretty pleased with the progress so far. The gas is old, which isn't helping but at least it is starting well. The choke cable was all bent up and sticky, straighten and lubed it up and is working pretty good now. The throttle return spring was anchored to the rubber hose running to vacuum line on the distributor! Where is the throttle return spring supposed to go? Anyway, I put together a bit of a walk-a-round video. I should have a new master cylinder tomorrow... might get a drive around the block!
https://www.youtube.com/watch?v=X4v7...ature=youtu.be
