Old 03-16-2015, 07:57 PM   #21
paul2748
paul2748's Avatar
Default Re: Power steering - 1954
I can't understand why some one would reply to a question that was four years old.
Old 03-17-2015, 06:29 PM   #22
54vicky
54vicky's Avatar
I am with you Paul but have seen even older ones answered years later.strange but true
54vicky is offline   Reply With Quote
Old 03-18-2015, 10:10 AM   #23
scicala
scicala's Avatar
I think people just see the post and don't notice the date, then reply. I remember doing it once on a post that was very old, and felt stupid for doing it after I noticed the date. Then it started a chain reaction of replies again.
Sal
Old 03-18-2015, 01:08 PM   #24
Jimz Bird
Jimz Bird's Avatar
I don't mind seeing that happen.
It brings up something that I probably have missed so I usually find it interesting. Also, there may have been new ideas or something that has been "discovered" to work in the interim.
Jimz Bird is offline   Reply With Quote
Old 03-19-2015, 04:59 PM   #25
cuppy65
What year volvo is the electric pump from?
Dan
cuppy65 is offline   Reply With Quote
Old 03-19-2015, 05:37 PM   #26
JeffB2
JeffB2's Avatar
And if anyone is looking for an original power steering setup from a '54 Ford one just got listed on www.1954ford.com
JeffB2 is offline   Reply With Quote
Old 04-14-2025, 06:21 PM   #27
Jack Innes
Jack Innes's Avatar
It appears this whole posting was lost in my computer. Thanks everyone for their input. I found a complete original setup & it is installed & working.
The cylinder leaked so I installed a rebuild kit & it still leaks a bit.
What fluid are people using in these units now?
Jack Innes, Brooklin, Ontario
Jack Innes is offline   Reply With Quote
Old 04-14-2025, 07:27 PM   #28
paul2748
paul2748's Avatar
Original system ? They used trans fluid when these were new. Type A was the original, but Type F may work, but Dexron III is the fluid closest to Type A. POWER STEERING FLUID is not recommended for these units as this tends to cause leaks..
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-14-2025, 09:26 PM   #29
Jack Innes
Jack Innes's Avatar
Thank you, I will go with Dextron.
