#1 | |
Thanks Kevin
Throttle Benders Est. 1949
#2 |
Kevin-
You have a '41 spindle NOT a '42-'48. Again, use a 48 pitman arm and a '41 drag link.. Tom |
#3 | |
#4 |
Really GOOD write-up above, Tom. You obviously understand this oddball 1941 stuff. DD
#5 |
I found an old pic before it was all taken apart to restore the front end
Does this help?
#6 |
#7 |
Randy-
To the best of my knowledge the only year Ford used a top fit drag link spindle was in '41 (11A-3105). I have never seen a round spindle only the square type but that doesn't mean a round type doesn't exist. It just means I have never seen one. Enclosed is a picture of a '41 spindle on my '35. It is not the best picture but if you look closely you can see it is square with a top load drag link end. As I understand it, Ford did not make the spindles. So, it could be "possible" that spindles were made by two different suppliers with different backing plate platforms. I doubt if Ford engineering would allow it but, it "could" be possible. Tom Last edited by flatheadfan; 09-09-2016 at 02:07 AM. Reason: spelling error |
#8 |
Another picture:
#9 | |
I admit to not knowing a lot about the 1941 spindles, other than they're the "odd man of the bunch" and that they're not even all the same from one model to the next. This is the first I've ever heard of a "square back" 1941 though - perhaps a very late version? Are you sure your's are from 1941 and that they couldn't be 1942 or later with the tie rod arm ends re-tapered? |
#10 |
Randy-
I bought them new ($5), from a local Ford dealer in 1960 when I was converting my '35 over to hydraulics. As I recall the part number was on the tags. They are definitely untouched '41s. Tom |
#11 |
The arrow is pointing to the tie rod, the drag link is behind it and the ball is entering from above. All tie rods enter from below, regardless of year.*
*Edit: Post 34 that is. Last edited by Mart; 09-09-2016 at 03:32 AM. |
#12 |
Mart-
You are correct, all tie rods enter on the bottom. Only the '41 drag link is attached from the top. I think there has been a misused of terms. The drag link is the what the question is about not the tie rod. Thanks Tom |
#13 |
The square back spindles on my 42 pickup were tapered from the top, I've used square back spindles a time or two in the past, these were also tapered from the top. Talking about the drag link hole in the spindle.
I'd say that it ain't only 1941 that was tapered from the top, I believe the only round back spindles tapered from the top are 1941. Just my observations an experience. Martin. |
#14 |
Seems to me we're talking "apples and oranges" here. Are we referring to the tie rod or the drag link or what? If you re-read my previous post I stated "the tie rod end coming up from the bottom the same as all other 1942-48 spindles". I didn't even mention the drag link, but I could have also added that as far as they go all 1942-48 enter from the top. I stand by my statement that the one pictured above by Kevin is a 1942-48 as it meets all of these criteria.
#15 |
Seems like this post series is getting more and more confused. Tie rods connect on the bottom. Whereas the '41 drag link (also possible some '42s) connect from the top and use a 11A-3306-B (bent design). The '42-'48 use 21A-3306 drag link (non bent). Evidently, 41's can have a round or square back. This should keep everybody happy!
![]() Tom |
#16 |
Well I see that you have edited you original post (#28) Tom, replacing the original "tie rod" with "drag link" and citing the reason as a spelling error. However your original post to which I was replying and where you were referring to tie rod ends is still highlighted in red were I quoted it and replied in post #30. I have often thought that the edit function is frequently abused and this is but one more example.
#17 |
Well, as you can see from my first post, I was confused from the beginning, and it hasn't gotten much better! (from my prospective of confusion). Now I'm headed out to the garage to look at some spindles!!!!
#18 |
That help! Thanks Coop.
#19 |
Just to make it even hard for anyone reading this. I cut up a rough 42 ford business coupe and it had round back spindles and the early style 1939 to 41 backing plates. This was an all original car that wasnt pieced together or parts swapped around. Fricken round back spindles!!!
#20 | |
