Old 12-27-2015, 11:26 PM   #21
5window
5window's Avatar
Default Re: Brumfield
Originally Posted by Houdini View Post
I took a second look at mine and what I thought was a B-R is in fact a
B-F. It must be the glasses. (actually, it was more likely the time from reading the letters and walking back into the house to type my earlier post that changed it from an F to a R). Should have done like I do when we go to bed at night and check 4 or 5 times to make sure the house doors are locked. Now going into a room and forgetting why you did is another problem.
I believe this was also purchased in the mid 90s, around 1997, so should I assume its a 5.9. Just wondering.
As long as that room's not the bathroom, I guess you'll be okay.
5window is offline   Reply With Quote
Old 12-27-2015, 11:36 PM   #22
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
It was the most common but it could be higher, Here is an old ad;
brumfield head
Old 12-28-2015, 12:07 PM   #23
Houdini
Houdini's Avatar
Mike, thanks for the link, it was informative to read.
Houdini is offline   Reply With Quote
Old 12-28-2015, 08:58 PM   #24
Dodge
someone posted a chart on here somewhere that uses a compression gauge reading
to approximate the compression ratio
Dodge is offline   Reply With Quote
