#21 | |
I love reading posts in "muscle car" forums by guys bragging about how wide their plug gaps are. In our world, all mammoth plug gaps do is wear out your ignition system in a big hurry. |
#22 | |
#23 |
Since all wires has resistans and the power to the ignition originally is taken between the generator and the battery you should in theory get a cleaner power if you attach the ignition directly to the battery pole.
#24 |
Maybe if I were using a generator, the interference would be different from using an alternator.
Anyway, I haven't had any issues. Thanks, J for the diagram/help Jim |
#25 |
An alternator would be the same basic arrangement. You most likely have an internal regulator, but the alternator, battery and vehicle loads are all still in parallel and all connected to ground. The battery is still acting as a buffer for the alternator with the same issues of what else is riding on the alternator output and what, if anything, messes with the electronics. I would guess not much as yours seems to be working fine! The interference would be different between an alternator and a generator.
#26 |
#27 |
My '47 has an alternator and electronic crab. Been running a number of years without any problem. Babba made me a matching spare kit including coil which I keep in my trunk (along with a carb and pump). If the electronic dies, I just need to do the swap and I'd be ready to continue.
