Old 10-20-2014, 04:01 PM   #1
abbie
Default head gasket
When using a copper head gasket and A "Z" head, aluminum; does the smooth side of the gasket go to the block or against the head? thank you
abbie is offline   Reply With Quote
Old 10-20-2014, 04:40 PM   #2
J Sims
Default Re: head gasket
You must install with the large water passages on the end,matching the holes in the block, One end is larger than the other.
J Sims is offline   Reply With Quote
Old 10-20-2014, 04:53 PM   #3
stevests
stevests's Avatar
Large water passage goes to the rear - no matter what.
stevests is offline   Reply With Quote
Old 10-20-2014, 06:50 PM   #4
redmodelt
redmodelt's Avatar
In any case the smooth side goes down the reason being that the edge of the fire ring will after time leaves it mark and it's easier to mill the head then the block. Don't forget to seal with copper coat.
Old 10-20-2014, 06:57 PM   #5
abbie
Thank you very much. That is what I will do in the AM
Old 03-14-2016, 05:55 AM   #6
Ed Saniewski
Ed Saniewski's Avatar
When torquing down the aluminum Z head, can I do it when the motor is hot like a cast iron head, or should I wait until it cools down. I love the power increase that I got from the higher compression.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 03-14-2016, 07:45 AM   #7
Jack Innes
Jack Innes's Avatar
Jack Innes, Brooklin, Ontario
Jack Innes is offline   Reply With Quote
Old 03-15-2016, 05:41 AM   #8
Ed Saniewski
Thanks Jack .
