Old 05-13-2014, 08:51 PM   #1
Carl Rismiller
Default fuel line
I am building a stock t speedster and like to know what size fuel line do I need to run. Thank You
Carl Rismiller is offline   Reply With Quote
Old 05-13-2014, 09:01 PM   #2
jackdaron
Default Re: fuel line
Carl,I use 5/16 tubing and run it outside the frame.
jackdaron is offline   Reply With Quote
Old 05-14-2014, 09:41 AM   #3
Steve Jelf
Steve Jelf's Avatar
I've read that steel is better for a fuel line than copper, which is more susceptible to metal fatigue.
Steve Jelf is offline   Reply With Quote
Old 05-14-2014, 10:13 AM   #4
yachtsmanbill
yachtsmanbill's Avatar
5/16" OR 3/8" steel line with a tank shut off and another shut off at the carb for those lunch stops. Being marine oriented (boats that is!) I ran a secured steel line along the frame to the fire wall, then a rubber vibration section to the valve on the carb. Keep it simple; keep it functional! ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 05-15-2014, 07:23 PM   #5
Carl Rismiller
Thanks guys I got this speedster last fall and just started getting things worked out. First the fuel line was all rubber and was right along the ex pipe and had a few burns in it so that is a good place to start.
Carl
