The Ford Barn
-   Model T (1909-1927) (https://www.fordbarn.com/forum/forumdisplay.php?f=2)
-   -   fuel line (https://www.fordbarn.com/forum/showthread.php?t=139508)
Carl Rismiller 05-13-2014 08:51 PM
fuel line
I am building a stock t speedster and like to know what size fuel line do I need to run. Thank You
jackdaron 05-13-2014 09:01 PM
Re: fuel line
Carl,I use 5/16 tubing and run it outside the frame.
Steve Jelf 05-14-2014 09:41 AM
Re: fuel line
I've read that steel is better for a fuel line than copper, which is more susceptible to metal fatigue.
yachtsmanbill 05-14-2014 10:13 AM
Re: fuel line
5/16" OR 3/8" steel line with a tank shut off and another shut off at the carb for those lunch stops. Being marine oriented (boats that is!) I ran a secured steel line along the frame to the fire wall, then a rubber vibration section to the valve on the carb. Keep it simple; keep it functional! ws
Carl Rismiller 05-15-2014 07:23 PM
Re: fuel line
Thanks guys I got this speedster last fall and just started getting things worked out. First the fuel line was all rubber and was right along the ex pipe and had a few burns in it so that is a good place to start.
Carl
