Old 02-22-2014, 06:24 PM   #21
1931 flamingo
1931 flamingo's Avatar
Default Re: 1930 Steering column support change
Old time radiator repair shop maybe??
Paul in CT
Old 03-04-2014, 12:15 AM   #22
flipp
flipp's Avatar
Paul in CT
Can I add this column support to my 1929 Model A or is this for 30 and 31 only?
Thanks, Flamingo!
flipp is offline   Reply With Quote
Old 03-04-2014, 12:28 AM   #23
CarlG
CarlG's Avatar
Check out this thread:
http://www.fordbarn.com/forum/showth...column+support
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-04-2014, 12:59 AM   #24
dumb person
dumb person's Avatar
Originally Posted by Tom Wesenberg View Post
Drain the tank, clean the area around the leak, and use a heavy soldering copper or propane torch with a soldering tip to resolder the area. That's how my Tudor tank bracket was fixed many years ago and it's still leak free.
So.. when you put a torch near a gas tank, is it a good idea to puncture one of those CO2 canisters they use in life jackets & pellet guns & drop it inside the gas tank to displace the oxygen & fuel vapors?
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 03-04-2014, 01:18 AM   #25
flipp
flipp's Avatar
Originally Posted by CarlG View Post
Thanks, Carl! This is exactly what I needed.
Old 03-04-2014, 01:49 AM   #26
Tom Wesenberg
Tom Wesenberg's Avatar
I don't know as I've never used one of them. If the tank is dry and clean around the area to be soldered, the flame should present no problem since it's about 3" back from the tip, which is the part touching the steel and doing the heating and soldering. It's about the same as using the heavy old soldering coppers, but with the torch you have constant heat.
Old 03-04-2014, 02:08 AM   #27
Mike V. Florida
Mike V. Florida's Avatar
If the flame is not near the open end of the gas tank all should be good.
Old 03-04-2014, 07:49 AM   #28
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Originally Posted by 2manycars View Post
That clamp will fit all 30 and 31, except the dropped column models, like the vic and 2dr phaeton. It will also fit the 28-29 if you make a shim, which is either 1/4 inch or 3/8 inch, I cant remember, and drill one hole. I did it to Barry's 29 special coupe.
Yes, good job Bill. For information to others, don't use the lower clamp along with the upper drop bracket, it will set up a horrible vibration that will crack the lower tank area and cause a fuel leak.
Barry B./ Ma. is offline   Reply With Quote
Old 03-04-2014, 09:46 AM   #29
marc hildebrant
marc hildebrant's Avatar
Not a good idea. The escaping CO2 will cause the metal canister to become airborne and cause injury.
Marc
marc hildebrant is offline   Reply With Quote
