Old 05-27-2010, 10:17 PM   #1
Flathead
Flathead's Avatar
Question 1930 Steering column support change
When you change from the gas tank mounted support to the dash rail mounted support, what happens to the old mount under the tank? Mine is not leaking, but I don't want to wait until it does. Does the new bracket hold the column clear of the old bracket? Do you have to cut the old one off? I hope to just leave the old one in place but not clamped up.
Flathead is offline   Reply With Quote
Old 05-27-2010, 10:30 PM   #2
JDakota
Default Re: 1930 Steering column support change
I just replaced mine, the old bracket (top piece) stays put but leave about 1/8 " clearance all around it so there is no contact. I had to shim the new bracket with washers to get the correct clearance. There is a Ford Barn post that shows photos of a shim they used. It may help to loosen the steering sector on the frame and then tighten the top bracket and then tighten the bottom end last.
JDakota is offline   Reply With Quote
Old 05-28-2010, 12:01 AM   #3
pat in Santa Cruz
pat in Santa Cruz's Avatar
leave out the rubber and the lower half of the original and there should be about 1/8th inch clearance. I have seen some with the lower half and no rubber too, which does not contact the steering column either.
pat in Santa Cruz is offline   Reply With Quote
Old 05-28-2010, 12:47 AM   #4
1930ABONE
1930ABONE's Avatar
Does anyone have a pic of how the conversion is done?
1930ABONE is offline   Reply With Quote
Old 05-28-2010, 07:49 AM   #5
Bill Steiner
pSteering sup 1.jpgI will try to put a picture. hope it will work. Bill
Bill Steiner is offline   Reply With Quote
Old 05-28-2010, 07:55 AM   #6
Bill Steiner
I shimed it with two washers so it would not touch the old upper clamp. I put a rubber piece in the old top part just for looks. you can see it in the picture. I used two bolts that where under the dash rail. I did not Drill under the dash rail for the third bolt. I don't see where it was needed. Bill
Old 05-28-2010, 01:35 PM   #7
Flathead
Flathead's Avatar
Thanks for the replies and helpful info! I am ready to make the change.
Old 05-28-2010, 03:34 PM   #8
1930ABONE
1930ABONE's Avatar
Thanks for the pic Bill!
I assume this change can be done on all 1930 body styles?
Old 05-28-2010, 06:06 PM   #9
2manycars
2manycars's Avatar
That clamp will fit all 30 and 31, except the dropped column models, like the vic and 2dr phaeton. It will also fit the 28-29 if you make a shim, which is either 1/4 inch or 3/8 inch, I cant remember, and drill one hole. I did it to Barry's 29 special coupe.
2manycars is offline   Reply With Quote
Old 05-28-2010, 10:39 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by Bill Steiner View Post
pAttachment 4402I will try to put a picture. hope it will work. Bill
Tony S Florida has a set of pics but has not been able to master posting pics on this forum. He has step by step photos. I went to his house a short while ago and we were only able to post pics 25% of the time.
I'm going to have to check home to see if I still have them on my home computer.
Go to Ahooga.com I see there is a thread about this same thing and Tony has posted the pics.
Old 05-29-2010, 12:36 AM   #11
hydroshawn
hydroshawn's Avatar
What is the purpose of adding a secondary column drop?
Thanks
hydroshawn is offline   Reply With Quote
Old 05-29-2010, 01:07 AM   #12
Mike V. Florida
Thanks
When entering and exiting a model A the driver often graps the steering wheel to assist him/her into the seat. This pulling, over time, can and has loosened rivits, cracked the solder and causes gas leaks.
Old 05-29-2010, 06:37 AM   #13
LeRoycoupe/N.Y.
Flathead, Mike V & Tony should be able to help you.
2/344151 & 2/384792 I copy 11/5/08
LeRoycoupe/N.Y. is offline   Reply With Quote
Old 05-29-2010, 07:26 AM   #14
hydroshawn
hydroshawn's Avatar
Got it. Is there realy no way to fix this or is it better to leave it & go with the secondary.
Old 05-29-2010, 02:31 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
If the bracket is not leaking, a good way to keep it in good shape is to turn the steering wheel with both hands, so as you turn the force is straight down the steering shaft. Turning the steering wheel with one hand (as when using a suicide knob) will put side pressure on the bracket and flex the bottom of the gas tank where the bracket is riveted.
Also don't grab the steering wheel for support when getting in and out of the car.
Old 02-22-2014, 04:21 AM   #16
flipp
flipp's Avatar
I just found a small gas leak in this particular area. I think I screwed up by adding a rubber bushing to the steering shaft. It has a very small crack on the solder. No wonder there's a strong gas odor inside the car.
What is the best fix for this?
Sorry, didn't mean to highjack this thread.
flipp is offline   Reply With Quote
Old 02-22-2014, 07:53 AM   #17
Mike V. Florida
BEST fix or just a fix. You will not like the BEST fix.
Old 02-22-2014, 09:46 AM   #18
flipp
flipp's Avatar
Just a fix, Mike.
Old 02-22-2014, 09:46 AM   #19
Tom Wesenberg
Drain the tank, clean the area around the leak, and use a heavy soldering copper or propane torch with a soldering tip to resolder the area. That's how my Tudor tank bracket was fixed many years ago and it's still leak free.
Old 02-22-2014, 02:26 PM   #20
flipp
flipp's Avatar
Ok, I'm going to find someone who can do this for me here in So Cal. Do any of you know someone who can do this type of work? I'll pay good money.
Thanks guys!
