Old 06-07-2013, 05:52 PM   #1
46WINE
Default 59 ab
I recently received a flathead block without the studs screwed in. I know there is 3 different sizes, but I don't know which one goes where. Does anyone have a "map" as to the layout of the studs??
Thanks
46WINE is offline   Reply With Quote
Old 06-07-2013, 05:59 PM   #2
Mart
Mart's Avatar
Default Re: 59 ab
Do you have a head? Look carefully at the thickness of the head, you should be able to see the three distinct lengths.
If you have aftermarket heads, you may need different length than stock, is as much as you might need the long ones all the way around.
Mart.
Old 06-07-2013, 06:15 PM   #3
Jack E/NJ
Jack E/NJ's Avatar
Default Re: 59 ab
As a general rule, the longest studs go nearest the intake manifold and shortest nearest the exhaust manifold. The in-betweenies go, well, in between the longest and shortest. 8^)
Jack E/NJ
Old 06-07-2013, 06:40 PM   #4
Ol' Ron
Ol' Ron's Avatar
Default Re: 59 ab
Use bolts.
Old 06-07-2013, 07:05 PM   #5
Karl Wolf
Karl Wolf's Avatar
Default Re: 59 ab
Put the head in place, or on a table- drop studs in holes... The amount left exposed on top should be about equal... And, seems (my memory) the in between size is only two studs, go in the centerish row, about 1/4-1/3 of the way from the end...
I would install with non hardening permattex- NOT silicone.
Karl
Karl Wolf is offline   Reply With Quote
