Old 05-21-2013, 01:03 PM   #1
Brambleworth
Brambleworth's Avatar
Default Tubular rivet tool needed
Can someone tell me where I can buy a tubular rivet tool? I need to replace the rivets that hold the hood leather corners on.
Brambleworth is offline   Reply With Quote
Old 05-21-2013, 01:05 PM   #2
Jim Parker Toronto
Jim Parker Toronto's Avatar
Default Re: Tubular rivet tool needed
Try a leather store such as Tandy's, or any motorcycle leather shop....
Jim Parker Toronto is offline   Reply With Quote
Old 05-21-2013, 01:12 PM   #3
RonC
RonC's Avatar
These people have all the rivet stuff for the Model A's and T's
http://www.bigflatsrivet.com/index.html
RonC is offline   Reply With Quote
Old 05-21-2013, 01:12 PM   #4
ericr
ericr's Avatar
Restoration Supply
ericr is offline   Reply With Quote
Old 05-21-2013, 01:27 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I'm pretty sure I used the brake rivet tool I bought from Bratton's many years ago.
Putting a drop of oil on the handheld rivet tool helps it make a neat rolled lip.
Old 05-21-2013, 01:31 PM   #6
spike
tonka toys .... c clamp made into tub rivit tool....works great.
spike is offline   Reply With Quote
Old 05-21-2013, 01:49 PM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
There are two good ones available IMO. I happen to own both but the one we are most partial to is to one that is made from a clamp and used in the Tonka Toy truck restoration, --or one used in riveting linings onto Model-T Ford transmission bands. Both of these are available on eBay all the time. Below are a couple of pictures showing what to look for.
When you have one that requires the use of a hammer, then you need a minimum of 3 hands and you run a huge risk of a misplaced blow.
File Type: jpg $(KGrHqVHJB8FCFl7PUrIBQmyZ5Rqmg~~60_12.JPG (39.0 KB, 124 views)
File Type: jpg $(KGrHqFHJC0FCzLJusM0BRPd0DSRrQ~~60_35.JPG (21.8 KB, 111 views)
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-21-2013, 08:53 PM   #8
Kevin in NJ
What I found worked great was my floor mounted kick riveter used to set brake shoe rivets.
One person holds the part the other does the fine line up and kick.
So if you know of someone that will give you the 10 minutes on their machine you need ask. I am too far south unless you are planing a trip to Atlantic City, NJ then you just need to go 8 minutes out of your way.
Old 05-22-2013, 07:37 AM   #9
1931 flamingo
1931 flamingo's Avatar
I used little tiny machine screws from loew's, nuts, lockwashers, cut the screws real short, little dab of black paint on the screw head, looks like it's rivited. FWIW
Paul in CT
