A friend asked if I could make some head puller for his Model A. I made some drawings, and this is how it ended up. Hope it will work.
Jorgen |
looks very nice.
You do know that you can pop the head by taking the head nuts off and turning the engine over.
Great idea. I'm surre that works pretty good especially if the head gasket was assembled using a lot of gasket sealer. In that event the head poping method only moves the head enough to release the combustion or compressed air. If you don't mind, I would like the dimensions so I can make one myself. Thanks. Don/WI
Try "Gord's Easy Head Puller" made only in one piece with a 100% history removal.
Gord/ B |
Rainmaker ron |
Yes... I know it was a little overkill, but my only ambition was to always keep the head puller plate perpendicular to the spark plug threads.
Jorgen |
Works GREAT!
PS, say HI to tubby (Darin)
If you take two old spark plugs and weld a T with one side longer then the other you can lift the head off after popping it loose.
