How can I tell if my grill is repop or original Ford? Think might be repop but want to make sure.
Super Moderator
I am not 100% certain about a '40 Ford V8 (aka Standard) grille but I am certain the '40 DeLuxe grilles had a date on the very bottom. It is small, perhaps less than 1/8" tall but it's there.
I am only guessing here but Drake is very fond of putting his name all over everything he makes so I look for that on a repop. Or, he's always saying how helpful his staff is, call them and ask...
Thanks grill I bought came in Drake boxes not sure if it is Drake or they put old grill on boxes when new one came in. Need to dig out and look so know what it is before selling it.
If it's a drake repop from the 80s, it's hard to tell. If I remember correctly, the only difference was the ejector pins form the mold and that was slight. The present ones are easy; they say Drake on them. I don't know when that started. Hre is a pic of an original
Original Grilles were of a Diecast material and probably had the Part Number cast into it on the backside. All the NOS Service Relacement grilles I have seen have had these numbers. Repros would not have these numbers.
#7 | |
Super Moderator
Is that "LH" on there?
The LH is there and it is cast not stamped.
I have a couple of known NOS V8 grilles that have never been assembled that were purchased long before Bob Drake started having them cast. I will look at them and take some pictures in the next few days unless Kube does this first. It would surprise me if LH or RH was cast along with the part # but could be.
#10 | |
Super Moderator
It took me a bit to gather up my spare grilles. I have both a left & right NOS as well as three used rights and two used lefts. NONE have any RH nor LH. I am confident that any grille with these markings is a reproduction.
Here is pic of the casting for the part number.
Sorry to hijack but I am in need of a nice standard grille I assume the drake repops are pretty nice?
Life is hard, after all it kills you! |
#13 |
So would Drake have cast the Ford part number or did someone else reproduce these?
#14 |
Might be one of Gene Scott's early creations. DD
