Old 01-25-2013, 05:32 PM   #1
Marv 119
Default 26 or 27 coupe?
Can anyone tell by these pics if this is a 26 or 27?As of now these are the only pics i have.
Marv 119 is offline   Reply With Quote
Old 01-25-2013, 06:03 PM   #2
jackdaron
Default Re: 26 or 27 coupe?
26-27 Model T coupe. Would need serial Number on side of block just above water inlet to tell more.
jackdaron is offline   Reply With Quote
Old 01-25-2013, 06:09 PM   #3
Willie in Houston
Willie in Houston's Avatar
I do not think there are many differences.
Have you tried looking at the serial number on the block. Also there is supposed to be a serial number on the frame somewhere near where the passengers feet would be.
(Remove floor boards first)
Willie in Houston is offline   Reply With Quote
Old 01-25-2013, 06:29 PM   #4
yachtsmanbill
yachtsmanbill's Avatar
Generally, at a glance Id say its a 1927 with the cross bar between the headlights. The 1927 used pretty much exclusively a vaporizer carburetor which has the throttle rod go across the top of the block. A true 1927 block wont have the rod "hole" between cylinders 2&3 nor the hole for the same through the valve cover. Also on that note, the throttle shaft alongside the steering column will only have on hole for a pin for the linkage arm towards the top just below the springs. If theres another hole down lower for the rod that goes through the block, then all bets are off. The '27 didnt have the lower hole but tons of parts have been swapped out over the last 85 years.
USUALLY, the 27s all had wire wheels getting tooled up for the 1928 model A run, but I think wood wheels were still available.
The block number will tell a lot and so will the frame number stamped on the rail top just inside the passenger door. That one is usually harder to read as the rail sprang when stamped. ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 01-25-2013, 11:03 PM   #5
Marv 119
Thanks for the info.I guess i will have to wait as i won't have access to it for a while.I was just hoping to get started on getting title info and need to know for sure the year.
Thanks Marv
Old 01-26-2013, 12:01 AM   #6
Steve Jelf
Steve Jelf's Avatar
Yep, that frame number is what you want. That will pin down the date of manufacture.
Steve Jelf is offline   Reply With Quote
Old 01-26-2013, 10:07 PM   #7
Farmallcub49
Farmallcub49's Avatar
Marv,
I would say Bill is right with the headlight crossbar being the best clue in the pictures. I think it is interesting that they took a 25 or earlier sediment bulb and screwed it into the tank; I am sure it work so that was all that mattered.
Also, welcome and it is great to see another Minnesotan. I am in St Joseph and stock new reproduction parts along with lots of used parts. We also do restoration and repair work; so we have lots of knowledge I can share if you have any questions once you start. I am past president of the Great Northern Model T Club and its current secretary. If you email me at [email protected], I can forward you our next newsletter and you are welcome to come to any our events and join if you like.
Andy
'OSO HANDY RESTORATIONS
Specializing in Model T Fords
320-293-1953
Farmallcub49 is offline   Reply With Quote
Old 01-27-2013, 10:06 AM   #8
Marv 119
Andy Email sent
Old 01-27-2013, 11:27 PM   #9
rotenjon
check the package try behind the seat, if its metal its a 26,Henry went back to wood in 27.
rotenjon is offline   Reply With Quote
Old 01-29-2013, 11:49 AM   #10
t42
Marv,
The 26/27 seat riser and pan under the front seat are different also.
t42 is offline   Reply With Quote
Old 01-29-2013, 11:53 AM   #11
yachtsmanbill
I removed a 26 trunk pan for my 27 and it was way different too. I still think the factory was trying to transition to the Model A with new bending/stretching techniques with sheet metal etc... ws
Old 02-04-2013, 10:24 AM   #12
t42
Marv,
Got any more pics, or info?
Old 02-04-2013, 06:04 PM   #13
Marv 119
No more pics yet. I hope to get the motor numbers and a few more pics the end of next week. It is in a garage that i don't have ready access to.
Marv
Old 02-20-2013, 07:21 PM   #14
bgarrett
bgarrett's Avatar
There were differences in the sizes of the holes in the inner doors and the parts around the rear window.
bgarrett is offline   Reply With Quote
