What does it take to attach a sbc to a 1950 Ford overdrive transmission?
I'm not asking about exhaust manifolds or dropped tierods or back bumper bolts, just what is needed to attach the SBC to the Ford transmission. |
Why? Surely you aren't going to ruin a Classic Ford by putting an inferior engine in it.
You should expect to not be received warmly when asking such a question on this forum. Many will tell you that the HAMB is a better place for SBC in a Ford. (You can go to "Forum Jump" at the bottom of this page and click on "hot rods and customs." If you're not a member of the HAMB, signing up there is just like signing up here.) Anyway, heres a link that should help you figure out what you want...
http://www.speedwaymotors.com/search...-adapters.html
Don't never get rid of nuthin! |
private message me and i can explane what i did.....
Your trannys are not going to last long,hope you have pleanty of spare gears. ken ct.
as long as your not doing burnouts your trans should last as long as if a flat head was in front of it
#8 | |
#10 | |
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
I would consider putting in a matching automatic tranny.
Gary. |
don't do it unless you like the sound of BOOM. T-5 is a much better choice. just an opinion...jack
Proud FNG We fixem cars. Heap Good! |
#13 |
Not an exact answer, but here's my suggestion... Call Wilcap Company, and ask. Wilcap/Sharp makes adapter's for almost anything. There is a really helpful gentleman, Mr Grant, who usually answers the phone, and he will likely know the answer.
805-481-7639 Pismo, CA Off subject, however... And, BTW... I disagree about the T-5. I can break them at will - a very weak choice, at least in Jeep's with very moderate power. I gather from comments posted here that T-5's work ok behind flathead power. Prudent and conservative driving habits seem to be effective for the T-5, and probably also for the Ford trans. Last edited by bobH; 11-27-2012 at 03:36 PM. |
#14 |
I appreciate the helpful comments
