Old 06-30-2010, 03:04 PM   #1
Charles Reese
Charles Reese's Avatar
Default Fender Paint
Don’t consider myself a particularly clever chap but do want to share a small trick that worked very well for me today. After painting the underside of a front fender was having trouble figuring how to hold it in such a way as to not scratch the bottom while painting the topside. Came up with a piece of wood stick/screw/washer through the headlight bar hole and block of wood under front inner edge of fender. Allowed me to get to all areas with gun without having to handle the fender.
The table is an old BBQ stand with wood slats mounted to top. Keeps things at waist height and great for rolling around garage/driveway for sanding/painting etc.
Charles Reese is offline   Reply With Quote
Old 06-30-2010, 03:24 PM   #2
MBI Houston
MBI Houston's Avatar
Default Re: Fender Paint
Neat idea, but more importantly, the paint looks great!
MBI Houston is offline   Reply With Quote
Old 07-01-2010, 12:03 PM   #3
FredK
FredK's Avatar
What kind of paint are you using? How easy is it to use?
Thanks
FredK is offline   Reply With Quote
Old 07-01-2010, 03:06 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Looks good!!!
Old 07-01-2010, 03:47 PM   #5
Charles Reese
PPG Concept 9300 .. last time i painted was 20+ years ago and that was with acrylic lacquer .. very forgiving ... this requires the standard reducer and a catalyst ... once i got the hang of it it seems to handle pretty much like lacquer did. what i dislike the most is short pot life (~90") where lacquer would keep mixed indefiniately ... i always seem to have some left over ($$$)
Old 07-04-2010, 01:01 AM   #6
pwh
pwh's Avatar
Thumbs up Re: Fender Paint
Very nice looking paint job. Thanks for sharing the idea of the stiff leg bolted through the headlight bar hole. I am about 2 weeks out of being there myself.
pwh is offline   Reply With Quote
Old 07-04-2010, 05:52 AM   #7
peters180a/170b
peters180a/170b's Avatar
Very nice looking fender. 9300 flows pretty good. just not too much at one time. Sands out well. Nice job ,good luck with the body..
peters180a/170b is offline   Reply With Quote
Old 07-04-2010, 06:10 AM   #8
allen
allen's Avatar
Send a message via ICQ to allen
If you ever sanded one of these fenders you know what a neat idea this is, first time i sanded one its was like trying to sand a ball it rolled ever where, great idea, this gives new meaning to bake on finished
allen is offline   Reply With Quote
