Old 02-01-2012, 08:33 AM   #1
Terry,OH
Terry,OH's Avatar
Default 49-50 master cylinder
What is the diameter of the piston in the 49-50 master cylinder? anyone have a photo of the set up linkage?
Terry,OH is online now   Reply With Quote
Old 02-01-2012, 09:14 AM   #2
V8 Bob
V8 Bob's Avatar
Default Re: 49-50 master cylinder
The '49-'51 Ford pass car master cylinder bore is 1", so the pistion will be slightly smaller. These masters are different than "normal" cylinders because they mount through the side and have intragal bracketry to support the clutch linkage. They were also used by other vehicle brands including (?) Kaizer. Pictures can be found on line, like Ebay, etc.
The '49-'50 pickup master has an 1 1/16" bore and is conventional in style and mounting, although with 3 bolts instead of two.
Old 02-02-2012, 07:21 AM   #3
Terry,OH
Terry,OH's Avatar
I have a master cylinder that I had thought could be 49-51 since it mounts from the side in two places. It has an elabrate mechanism to reverse brake rod motion and several of the features of the 49-51 master cylinder. The bore is marked on the side as 1. Is this 49-51? Note the large hex on the end can be removed to expose the internals.
Old 02-02-2012, 07:25 AM   #4
Cecil/WV
Cecil/WV's Avatar
I don't know about the bore size, but my '64 mEconoline pickup cylinder is the same externally.
Cecil/WV is offline   Reply With Quote
Old 02-02-2012, 08:36 AM   #5
V8 Bob
V8 Bob's Avatar
Nope, that's not a '49-'51 Ford master, this is.
Old 02-02-2012, 10:15 AM   #6
JoeWay
JoeWay's Avatar
That's a 1955 (second series) through 1959 GM truck cylinder. Probably 1-1/8" bore, used in 1/2 and 3/4 ton Chevy and GMC trucks.
In the GM chassis, the pedal pivots in the fork on the cylinder, with no added hardware.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 02-02-2012, 11:03 AM   #7
Rowdy
No pic's of the setup, but very likely I have a rebuild kit for these and possible I have a NORS or remanufactured master cyl when I start going through the brake parts. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-05-2012, 01:36 AM   #8
Fibber Mcgee
Fibber Mcgee's Avatar
My 41 Tudor and 49 F1 appear to be the same 3 bolts on front.I hope they are because I couldnt get a 41 at local auto parts house so I got a 49 and it stops great maybe someone could correct me.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 02-05-2012, 04:22 AM   #9
Mart
Mart's Avatar
41 passenger and 49 truck use the same master cylinder.
Mart.
