49-50 master cylinder What is the diameter of the piston in the 49-50 master cylinder? anyone have a photo of the set up linkage?
Re: 49-50 master cylinder Quote:
The '49-'50 pickup master has an 1 1/16" bore and is conventional in style and mounting, although with 3 bolts instead of two. :) |
Re: 49-50 master cylinder 1 Attachment(s)
I have a master cylinder that I had thought could be 49-51 since it mounts from the side in two places. It has an elabrate mechanism to reverse brake rod motion and several of the features of the 49-51 master cylinder. The bore is marked on the side as 1. Is this 49-51? Note the large hex on the end can be removed to expose the internals.
Re: 49-50 master cylinder I don't know about the bore size, but my '64 mEconoline pickup cylinder is the same externally.
http://i20.photobucket.com/albums/b2...ercylimder.jpg |
In the GM chassis, the pedal pivots in the fork on the cylinder, with no added hardware. Joe |
Re: 49-50 master cylinder No pic's of the setup, but very likely I have a rebuild kit for these and possible I have a NORS or remanufactured master cyl when I start going through the brake parts. Rod
Re: 49-50 master cylinder My 41 Tudor and 49 F1 appear to be the same 3 bolts on front.I hope they are because I couldnt get a 41 at local auto parts house so I got a 49 and it stops great maybe someone could correct me.
Re: 49-50 master cylinder 41 passenger and 49 truck use the same master cylinder.
Mart. |
| All times are GMT -5. The time now is 05:25 AM. |
