Old 05-30-2026, 12:22 PM   #1
SNAFU1929
Default Should I Worry or JB Weld it?
Saw this while lubing and doing an oil change. What are your thoughts?
1929 Model A Tudor
SNAFU1929 is offline   Reply With Quote
Old 05-30-2026, 12:26 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Should I Worry or JB Weld it?
JB Weld but clean thoroughly with solvent before using the epoxy. It looks like it was caused by something being forced through the housing from the inside. Check to see if there is something loose inside that would cause further damage. A bore scope might be good tool to use.
nkaminar is online now   Reply With Quote
Old 05-30-2026, 12:43 PM   #3
SNAFU1929
Great idea on the bore scope, although the hole might be too small, but I will order one and try it.
I am not sure if it was caused from the inside, the way it is broken, looks like something hit it from the outside. Not sure how to describe it, but it has like an inward cone shape (if that makes any sense).
My dad gave me this car last summer because he didnt want to drive it anymore, I drove it some 150-200 miles last season, but I didnt spend a lot of time crawling under it because he told me he had it lubed before sending it. So not sure if that is recent or old.
Anyway, I will try a borescope anyway, it wont hurt to try to look inside.
Old 05-30-2026, 12:45 PM   #4
old31
SANFU, welcome to the Barn.
Do you think that he might have a bolt inside that got caught and went for a ride?
Yes, jb will work, but you need to find out what did it.
I would remove the starter, get a flexible, powerful magnet and go fishing.
old31 is offline   Reply With Quote
Old 05-30-2026, 01:05 PM   #5
nkaminar
nkaminar's Avatar
A conical shape like that is more likely caused by something inside coming out. Whatever it was may be long gone. But it would be best to check. Removing the starter, like Old 31 suggested, is the best place to look inside.
Old 05-30-2026, 01:40 PM   #6
ModelA29
ModelA29's Avatar
Simple explanation - starter bendix bolt.
JB weld will do nothing but hide the hole.
Leave the hole it's a handy spot to shove a screwdriver to hold the engine while you tighten the crank bolt.
ModelA29 is offline   Reply With Quote
Old 05-30-2026, 01:44 PM   #7
SNAFU1929
Good ideas, I will work on that tomorrow.
Old 05-30-2026, 02:04 PM   #8
Trapdoor2
Trapdoor2's Avatar
Just another opinion: Yes, look for what did it on the inside. It does look like it has been there some time. Whatever did it may be long gone...but better safe than sorry.
I think I would probably just clean it up and install an expanding rubber plug or something like that. It doesn't look like it would cause structural problems. Maybe fix or replace the housing next time the engine is out.
'31 Ford Deluxe Coupe "The Green Hornet"
Trapdoor2 is online now   Reply With Quote
Old 05-30-2026, 03:00 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
First thing I thought of also. Best to pull the starter and fish around.
Old 05-30-2026, 05:14 PM   #10
J Franklin
J Franklin's Avatar
Leave a hole like that and might get mice looking for a home. Maybe buy a cork.
Old 05-31-2026, 09:30 AM   #11
Fullraceflathead
Fullraceflathead's Avatar
I would clean it thoroughly with acetone and JB weld it you can get a small borescope for less than $20 for an iPhone on ebay that will definitely fit inside there!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 05-31-2026, 09:48 AM   #12
Will N
Will N's Avatar
The hole is a perfect place for a crack to begin from. And look what's just above where your hole is- the motor mount. I for one would never feel completely comfortable that the flywheel housing, which bears the weight of the engine, wouldn't let go at some inopportune time it it were my car.
Will N is offline   Reply With Quote
Old 05-31-2026, 11:43 AM   #13
nkaminar
nkaminar's Avatar
Cracks propagate from sharp corners. That is why it is recommended to drill a hole at the end of a crack. Also the reason a glass cutter works.
Might be a good idea to smooth out any sharp corners in the hole before the JB Weld.
Old 05-31-2026, 03:48 PM   #14
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Just curious if anyone might have considered the stress risers that punched hole can/will create? The Flywheel Housing is subjected to severe duty from being one of the 4 crossmembers for a somewhat weak Frame. Secondly, consider the fore & aft forces that are generated as the vehicle is being driven. It is no wonder why so many Flywheel Housings are cracked.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-02-2026, 08:31 AM   #15
1crosscut
1crosscut's Avatar
Round the edges of the hole a bit. Cut a circular or square piece of cotton tee shirt material and saturate it with some RTV sealant and after cleaning the area with solvent apply the patch over the hole. Won't be a structural repair but neither will J.B. Weld. Keep an eye on it and drive it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
