#21 | |
Competent builders and machine shops are hard to find. Everything needs to be balanced separately. We have builders of the new engine that don't understand this and have the flywheel and pressure plate balanced together by only removing weight from the flywheel. Ford engineering in the 1920's was behind the competition. In 1914, the Dodge Brothers left Ford and started making their own automobiles. By 1927, their 40 HP Fast 4 engine used inserts on the 5 main bearings and 4 connecting rods. |
#22 |
I am going to make a wild guess that Ford's engineers knew a 5 main was the way to go. But Henry, being Henry, knew that a 3 main was cheaper and that is what he did.
#23 |
i think in the late 1920s selling an affordable car that Ford could mass produce cheaply was more important than having a bit of vibration.
the first Model A was completely solid mounted engine and tranny (which mine is). so without isolating the engine and trans assemblies there is bound to be vibration. Competition and consumer knowledge is what made cars nicer all around. If it wasn't Ford would still be building and selling Model Ts I kinda like driving old sh&# the way it was made 98 years ago. Embrace the vibes.
old ugly my mom would have told me. "these things are here to test us" |
#24 | |
#25 | |
#26 |
#27 |
#28 |
If the balancer is using centers at the ends of the crankshaft. The crankshaft has conical holes drilled in each end that was used to grind the bearings and is used to balance the crank. If the balancer presses in too hard on the ends it could possibly deform the crank at the flanges for the rod journals. The force is off center at those flanges.
Beware that sometimes the centers, the conical holes, are not on center and the journals at the ends should be used.
#29 |
When he says the word balancer he's referring to the machinist or machine operator of the balancing machine.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#30 |
Not an expert, but most balancing machines support the part on the journal or shaft surface- not between centers.
#31 |
That would be the best method. There is no guarantee that the centers are true.
#32 |
I have been working on alignment of the headstock and tailstock on my crankshaft grinder and with a skinny model T crankshaft and wondering what distortion is induced by varying the pressure on the centers and saw no changes with different pressures on the centers from the tension spring on the runout of the center main
