Old 05-14-2026, 02:00 PM   #19
Terry Burtz, Calif
Default Re: Does flywheel need to be balanced
Originally Posted by Seth Swoboda View Post
As I said, balance the entire rotating assembly. You don't need to be a genius to figure this out. Any competent automotive machine shop will do this without question.
Competent builders and machine shops are hard to find. Everything needs to be balanced separately. We have builders of the new engine that don't understand this and have the flywheel and pressure plate balanced together by only removing weight from the flywheel.
Ford engineering in the 1920's was behind the competition. In 1914, the Dodge Brothers left Ford and started making their own automobiles. By 1927, their 40 HP Fast 4 engine used inserts on the 5 main bearings and 4 connecting rods.
Terry Burtz, Calif is offline   Reply With Quote
