Old 03-07-2026, 06:52 AM   #1
fredeuce
fredeuce's Avatar
Default '53 Customline - Diff Gear Swap
I have a Ford style differential that was equipped with a 39/10 gear set. (3.9:1)
I am attempting to fit a later gear set that is 29/9 (3.22:1 ) to this early housing. I have discovered it does not fit and requires some relieving to get it to fit.
Clearly, there are different castings for these differentials.
Has anyone encountered this before ?
Has anyone relieved the housing for this purpose?
Is there a way of identifying these castings externally?
fredeuce is offline   Reply With Quote
Old 03-07-2026, 09:30 AM   #2
pistonbroke
Default Re: '53 Customline - Diff Gear Swap
Yes the casting is different for the later freeway fliers but, the whole third member will bolt into the 53 axle housing. Tim
Old 03-07-2026, 11:29 AM   #3
petehoovie
petehoovie's Avatar
Old 03-07-2026, 02:20 PM   #4
Newc
Newc's Avatar
52/53 Wagons use a different diff also Newc
Old 03-08-2026, 06:24 PM   #5
fredeuce
fredeuce's Avatar
After some closer examination of casting shown in the original post I had a look at another complete unit to ascertain if there was any difference. This unit has a 41/11 (3.73) gear set. Looking inside where my pinion is fouling I can see the casting is different and provides a relief in the area where the 9 tooth pinion fouls. Externally the casting is different around the filler plug area. See pictures. I am going to explore this housing and see if it takes the 9 tooth pinion.
Old 03-08-2026, 06:33 PM   #6
tubman
tubman's Avatar
Given the scarcity of these rear ends, could you please define the years covered by "early" and "late"?
Old 03-08-2026, 08:21 PM   #7
petehoovie
petehoovie's Avatar
Old 03-10-2026, 06:45 AM   #8
pistonbroke
I think they were used from 49 thru 56
Old 03-10-2026, 11:11 AM   #9
tubman
tubman's Avatar
I knew that, but what differentiates between "early" and "late"?
Old 03-10-2026, 03:01 PM   #10
fredeuce
fredeuce's Avatar
Generally speaking I think you can define early v late as Flathead powered v OHV powered however the use of an auto trans also determines the ratio used so the line between the two categories is a bit blurry.
Old 03-10-2026, 05:05 PM   #11
tubman
tubman's Avatar
Now I'm getting confused. Is this an "early/late" (e.g. '49-'53 vs. '54-'56) or a "carrier break" difference? ("Carrier break" is were you need a different carrier for high ratios vs. low ratios.) Anybody know for sure?
Just tryin' to add to my store of "shoebox knowledge".
Old 03-10-2026, 09:12 PM   #12
Gene1949
Gene1949's Avatar
Kinda off topic but related. I would mag [particle] the axles. I broke 2 of them, one on each side.
And no, my 16 year old self wasn't present.
Gene1949 is offline   Reply With Quote
