'53 Customline - Diff Gear Swap 2 Attachment(s)
I have a Ford style differential that was equipped with a 39/10 gear set. (3.9:1)
I am attempting to fit a later gear set that is 29/9 (3.22:1 ) to this early housing. I have discovered it does not fit and requires some relieving to get it to fit. Clearly, there are different castings for these differentials. Has anyone encountered this before ? Has anyone relieved the housing for this purpose? Is there a way of identifying these castings externally? |
Re: '53 Customline - Diff Gear Swap Yes the casting is different for the later freeway fliers but, the whole third member will bolt into the 53 axle housing. Tim
Re: '53 Customline - Diff Gear Swap Quote:
https://www.fordbarn.com/forum/attac...5&d=1772884255 |
Re: '53 Customline - Diff Gear Swap 52/53 Wagons use a different diff also Newc
Re: '53 Customline - Diff Gear Swap 2 Attachment(s)
After some closer examination of casting shown in the original post I had a look at another complete unit to ascertain if there was any difference. This unit has a 41/11 (3.73) gear set. Looking inside where my pinion is fouling I can see the casting is different and provides a relief in the area where the 9 tooth pinion fouls. Externally the casting is different around the filler plug area. See pictures. I am going to explore this housing and see if it takes the 9 tooth pinion.
Re: '53 Customline - Diff Gear Swap Given the scarcity of these rear ends, could you please define the years covered by "early" and "late"?
https://www.fordbarn.com/forum/attac...4&d=1773012149 |
Re: '53 Customline - Diff Gear Swap I think they were used from 49 thru 56
Just tryin' to add to my store of "shoebox knowledge".:) |
Re: '53 Customline - Diff Gear Swap Kinda off topic but related. I would mag [particle] the axles. I broke 2 of them, one on each side.
And no, my 16 year old self wasn't present.:D |
| All times are GMT -5. The time now is 04:51 PM. |
